Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-19-2005, 01:51 AM
CivicRacerB16 CivicRacerB16 is offline
building ls/vtec
I'm just starting to put together all the parts and stuff that I need to build an ls/vtec. I have a b16a right now I have the ls block. I'm gonna buy some eagle rods. But my questions is if I should balance the crank shaft or not. I want this to be reliable even though its not my daily driver and I'm going to be going na. Oh, and should I get the i or h eagle rods?
Old 01-19-2005, 02:54 AM
Dweezil6969 Dweezil6969 is offline
Re: building ls/vtec
If your planing on raising the rev limit on the short block, have it ballanced with the rods and pistons your using just to make sure you don't blow anything apart.
`91 CRX DX Kind of moves
`90 CRX Si
Can also be found on:
XceedSpeed.com, MichiganCivics.com, and Zilvia.net
Old 01-19-2005, 11:38 AM
I'm only planning on revving it to like 8500 maybe not even that cuz I don't think the stage one cams r gonna make power that high. And for pistons I'm gonna go with the sir pistons cams r gona be skunk2
Old 01-19-2005, 12:29 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
yeah you should balance the crank. it will help with the higher revving you plan on doing.
Team Lonely Drivers
Old 01-19-2005, 04:30 PM
sounds good, thanks for the help.
Old 01-20-2005, 12:00 AM
2slowrex's Avatar
2slowrex 2slowrex is offline
are u putting pr3 pistons or p30?
Old 01-20-2005, 01:05 AM
I'm not to good with stuff like that, but I believe the p30 r si pistons. corret me if I'm wrong. I wanted to go with the ctr pistons but I heard that the sir pistons will have a higher compression. Like I said I have a jdm b16a so I'm just gona use those pistons if they still look good and buy new rings.
