Old 01-19-2005, 12:59 AM
MikeCook MikeCook is offline
Check Oil Light
I have a 1996 cavalier Z24. The check oil light comes on when I start the car. If I turn the car off and start it again the check oil light goes off. My oil level is not low. Since this problem has started I changed my oil. Any ideas of what the problem is?
Old 01-19-2005, 10:17 PM
public's Avatar
public public is offline
Re: Check Oil Light
Many GM cars have a sensor in the oil pan that detects low oil level. Your may be bad.
Yes, I am retarded.
Old 01-22-2005, 03:01 PM
noshun's Avatar
noshun noshun is offline
Re: Re: Check Oil Light
Do you park on a slope? that can throw it off!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 01-22-2005, 04:40 PM
public's Avatar
Re: Re: Re: Check Oil Light
True... I live in Fla. so I did not think of that.
Yes, I am retarded.
Old 07-01-2005, 05:20 PM
I replace the oil sensor in the pan but I still have the same symptoms. Any other ideas of what is causing the problem?
Old 07-02-2005, 07:52 AM
public's Avatar
Re: Check Oil Light
Bad ground on the oil pressure sensor. Check your plug.
Yes, I am retarded.
Old 08-18-2005, 03:00 PM
Red Rider 2 Red Rider 2 is offline
I have a 92 Caprice with 56k miles. The low oil light was coming on sporatically, but never low oil. As part of routine maintenance, I changed the O2 sensor. The low oil light didn't come on for several months. I thought that was the fix. However, a couple of days ago, it came on and has stayed on while the car is running. I'm going to change the oil sensor in hopes the problem goes away.
