Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-19-2005, 12:41 AM
notsmartguy notsmartguy is offline
2000 Jimmy Door Dropping
When I open my driver's side door it drops and I was just curious how I would go about fixing that. In my old car you would have just tightened the bolts on the hinges but since this car uses pins I am a little less than useless. Sorry I suck at this kind of stuff so any help would be appreciated.
Old 01-19-2005, 05:11 AM
GMCTech GMCTech is offline
The hinge pins and bushings will have to be replaced.
It is a fairly easy job, but is much easier with the correct tools.
Might end up being cheaper and less knuckle busting to have a shop do it that has done a few of them.
Hope this helps.
Old 01-19-2005, 04:07 PM
What all would be involved? I am pretty smart and can do most of it I just need directions.
Old 01-20-2005, 04:44 PM
Fezwig Fezwig is offline
Re: 2000 Jimmy Door Dropping
I just did one of mine a couple of weeks ago.
I think I spent six bux on one at O'reilly's. It was a pain but not enuf that I would send it to a shop.
I used a crowbar, flathead screwdriver, a punch and a hammer.
Get some help if you can. You can do it yourself, but I really needed another set of hands. The hardest part was getting the spring out.
You might want to check the other doors also. My passenger side is going to need it soon, too.
Good Luck.
Fezwig
Old 02-01-2005, 10:18 AM
Rockyrider Rockyrider is offline
Question Crowbar? Jack ?
Hey Fezwig,
I'm thinking of doing mine as well, it's a 97 and it's getting a bit tired. What did you need the crowbar for? Attitude adjustment hehe ?
Someone told me they jacked their door up and it worked fine. Anyone try that? I think if you jacked it up you may just end up loosening it further, and bending things would not be good.........
Old 02-02-2005, 04:41 PM
I hadn't thought about giving it an attitude adjustment! I sure felt like it.
The crowbar was for prying the spring out of the door. I wanted leverage on my side
Fezwig
P.S. I bet a jack would be helpfull (Now why didn't I think of that??)
Old 02-02-2005, 06:39 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
You can buy a door spring compressor for about 10 bux...Forget using a prybar...
