Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 01-18-2005, 11:45 PM
mchenson mchenson is offline
Unhappy door lock problem on 03
I need HELP!
does anyone know of a problem with the door locks on the 03. when i unlock them they immediately lock back, whether i use the remote or do it on the button on the door. i think it needs to be reprogrammed, but it might be a short in the electrical.
Any help or ideas would be appreciated!
Old 01-19-2005, 12:02 AM
Zero8985's Avatar
Zero8985 Zero8985 is offline
Send a message via AIM to Zero8985
Re: door lock problem on 03
i have a similar problem with my spyder, except that when i try and lock it, it unlocks on the driver side only and refuses to lock. The problem with mine is a short in the wiring, where my lock wire is grounding somewhere. Temporarily i sliced the wire so i can lock the car. Chances are you have a short somewhere, it shouldn't be a hard fix, it will just be hard to find.
*1997 Mitsubishi Eclipse Spyder GS /// SOLD
*1997 Jeep Grand Cherokee Limited
*2000 Chevrolet Cavalier Z-24 Convertible
My Spyder on Car Domain! Check it out!!!
My Jeep on Car Domain! Check it out!!!
Old 01-19-2005, 07:55 AM
perna00's Avatar
perna00 perna00 is offline
Send a message via AIM to perna00
on the newer eclipses there is a dumbass guard where if you leave the key in the ignition you can't lock them in the car. next time your in your car. turn it off, hit the power lock button and try to close them in. the locks will not remain locked, they will spring back unlocked. maybe in your 03 it thinks your key is still in the ignition?
***i just reread your thread, yours will not unlock. thought it was the other way around at first. probably a short. good luck.
Old 01-19-2005, 03:48 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
that would suck!! just old-school it and put the key in the lock to undo it, or an automatic door popper would work
Don't act like you don't love it.
503/2000
Old 01-19-2005, 10:32 PM
Angry
it does suck! but using the key actually does not work. I have to use the remote and pull the handle at just the right moment to get it open, usually takes 3-5 tries.
Thanks for the input, it probably is a short.
Old 01-19-2005, 10:51 PM
Stickin_It_2_Em's Avatar
Stickin_It_2_Em Stickin_It_2_Em is offline
Banned
Is your car a spyder or coupe? If its a coupe, does it have a sun roof? Do you see where Im going with this?
Old 01-20-2005, 08:51 AM
Zero8985's Avatar
It's almost definitely a short(but i can't be 100% sure). What's possibly happening is your power wire for your door locks is grounding somewhere on the car, or another wire, and the result is the equivalent of someone holding the lock button down.
Old 04-07-2005, 01:33 AM
Obsiniius Obsiniius is offline
I know exactly what you are talking about i have a 2000 gt Eclipse and have the same problem you unlock door and then it locks on its own mine does it while driving down the road it always locks never unlocks,if im setting with car running sometimes the doors will lock,make sure you leave a post here if you find a solution i will do the same
Old 04-10-2005, 04:13 AM
Hydro420Eclipse Hydro420Eclipse is offline
Send a message via ICQ to Hydro420Eclipse Send a message via AIM to Hydro420Eclipse Send a message via MSN to Hydro420Eclipse Send a message via Yahoo to Hydro420Eclipse
not sure if its standard but when i start my car and place it on drive my doors lock. when i turn my car off they unlock. but most likely its a short sumwhere. go to the dealership and tell them they sold u a lemon lol
hope u get the problem fixed
Old 04-10-2005, 05:03 AM
Back's Avatar
Back Back is offline
Banned
This is a standard option.
Old 04-10-2005, 11:12 PM
Zero8985's Avatar
this thread is almost 4 months old, also. No intentions on being an asshole or anything, but lets let this thread R.I.P.
