On my '89 s10 blazer it has the oil filter mounted right under the hood above the wheel and has 2 lines that run to the engine. on of them has sprung a leak and as far as i no they dont sell a replacement for this at an auto shop.... Has n e one experienced similar problems or n e suggestions as to wat i shouldb do???
Re: Oil!!!!
I just tried a parts store in my area for these oil lines and was told this is a dealer part, and this parts store almost always has what I need. Is the leak from the hose, where the hose connects with the threaded connection, or between the threaded connection and the filter mount?
I had the same problem on me 92 S-10 Blazer and what had happened was one of the o-rings blew. I looked everywhere for new o-rings(no success) and then new lines. Only place that had the lines was the dealer and they wanted almost $200! i'm a cheap bastard sometimes so remembering that my brothers 96 nissan truck engine calls for a gasket maker rather then gaskets for most of the components on his engine, i thought i would give it a try. I used permatex gasket maker on both oil lines and it has been over 4 years......still no leaks! I kept the old o-rings on the lines obviously and then applied gasket maker around the edge of the o-rings. Let it dry real well and hopefully if you try it, it will work for you like it worked for me. Good luck!!!!!!!!!!!!
Re: Oil!!!!
Some auto parts stores, Fairfax Auto near me, do have a large selection of o-rings so if thats your problem you can try to find a new one first.
