Old 03-11-2002, 09:08 PM
3y30wnj00 3y30wnj00 is offline
Send a message via AIM to 3y30wnj00
engine internals
is it better to match certain brands of engine components together (like rods & pistons, or valves, seats & and springs) ?
Old 03-12-2002, 11:20 AM
texan's Avatar
texan texan is offline
Writer Mod
It's important to match the componentry to your needs, but not to a name brand. An engine is a collection of parts which must work as a cohesive whole in order to perform optimally, all you need to do is select parts that will work well together and reach your power/reliability/cost goals.
'03 Corvette Z06
'99 Prelude SH
Old 03-12-2002, 01:05 PM
let me rephrase the question, do some companies (ie TODA) make their springs with their cams in mind so that they work better together than say TODA springs and Crower cams because Crower designed their cams to work best with their springs ? thats probably the biggest run-on-sentence youve ever seen.
Old 03-12-2002, 02:55 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Could be true, but would be a very rare occurance, and only for very high lift cams that required very strong valve springs.
You have to remember that all the aftermarket parts also have to interngrate with the stock parts, meaning they can then intergrate with each other.
I see no reason why you coudn't use TODA valve springs with Crower cams.
Old 03-12-2002, 04:26 PM
the crower cams and toda springs was just an example but thanks a lot for the info
Old 03-12-2002, 06:06 PM
Moppie's Avatar
Master Connector
Well its generaly true for most parts.
Theres no reason you cant mix rods and pistons from differnt manufactors, or even differnt cams. You just have to look at what each part does, and what other parts interact with it.
Then asses it on its own merits.
Useing the Valves springs as an example, its only important the spring will be strong enough to resist vavle bounce, and be well enough made that it won't break at high RPM. Who make's it is not important.
Old 03-12-2002, 07:43 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
I wouldn't agree that those are the ONLY criteria by which a valve spring must be judged, but they're on the list.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 03-12-2002, 09:56 PM
Moppie's Avatar
Master Connector
O.K. then I'll simplify my example
As long as the part correctly performs the required role then it dosn't matter who makes it.
:smoka:
Old 03-12-2002, 11:15 PM
fair enough. I was sorta hoping that you'd challenge me to come up with an exhaustive list (I'm not entirely sure I could do it, but I think I could come close). I must just like to read my own writing on the internet or something.
One obvious thing about cam selection vs valve spring selection that hasn't come forward in this thread yet would be the issue of solid clearance - if you have a valve spring design that gives a desired (small) solid clearance at max lift, and you increase max lift, there's a chance that you'll "go solid" before you get to max lift... that'd be a problem. Not that this means that you have to get the same brand cam & springs, you just have to keep in mind the intended specs of the NEW system when you're picking parts. (which is what you've been saying all along, of course)
I suppose that I might add that "valve bounce" is not as likely to be caused by improper spring selection as by excessive valvetrain vibration. I think what you were probably meaning to say is "valve float." (At least if we're giving the same meanings to the terms)
I call "valve bounce" the situation where the valve closes, then "bounces" open again (actually pushed open by vibrating valvetrain components)
I've heard of valvetrain separation (where the components at the various interfaces lose contact with each other, such as cam-follower, pushrod-lifter, etc) referred to as "valve float," but I prefer to call this behavior "separation."
Old 03-13-2002, 02:39 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
OK, here would be my definitions for discussion:
Valve float: At high-RPM, the momentum of the valve is too great for the spring to control and it leaves the prescribed cam lobe profile ballistically over the nose.
[/b]Valve train seperation[/b]: Whenever any of the valvetrain units - cam, (lifters, pushrods,) rockers, valves, or springs - lose firm contact.
Valve bounce - type I (lobe bounce): After an instance of valve seperation, the spring will be forcing the components back in to contact in an uncontrolled manner. The impact of the contact will compress elastic components. As they re-expand, they will impart an opposite force to the valve, causing it to 'bounce' open again.
Valve bounce - type II (seat bounce): If the lash is too great or the closing ramp too steep, the valve face will hit the valve seat with too much velocity, elastically compressing the valve diameter and the valve seat. As they re-expand, the valve will 'bounce' off the seat and open again - also causing seperation.
I'm also under the impression that valve bounce type I is usually caused by valve float.
For example: At an excessive RPM, the opening velocity is too great for the spring to control. The momentum of the spring/valve/rocker mass continues to compress the spring (continuing to open the valve) even after the rocker has passed the nose of the cam. This is the primary cause of 'valve float'. i.e. the spring does not have enough force to overcome the momentum of the valve assembly at high speed, thus the rocker leaves the surface of the cam lobe.
Now, the cam continues to rotate, rapidly increasing the distance between it's lobe face and the floating rocker. Eventually the spring force overcomes the momentum of the valve, and it reverses direction and begins to close, and therein lies the danger of valve bounce. The spring is now accelerating the valve closed as fast as physics allows - far faster than it would if it were following the cam lobe profile. At some point far down the closing ramp, perhaps even on the base circle, the rocker slams into the cam lobe. The elasticity in the cam, rocker, valve stem and spring absorb that impact and then reverse it right out, pushing back on the valvespring - once again causing seperation as the valve assembly 'bounces' off the cam lobe. Often times it can actually bounce several times as there is little damping in the system - keeping the valve intermittently open far past it's intended closing point.
From my personal experience, the biggest problem for street/strip engines is usually valve float - which then causes seperation and often valve bounce (type I). Although interestingly enough, in serious money racing, where valve lift and duration are restricted, some cam designers are now modifying the profile to intentionally cause valve float! A steep ramp right up to the nose will launch the valve right off. It'll open the valve further and keep it open longer, and the closing ramp is intended to 'catch' the valve smoothly to prevent bounce. But the mechanical dimensions of the cam lobe are still within spec. Tricky, eh?
Old 03-13-2002, 02:45 PM
fritz, do you work in the car industry somewhere or do you just know everything?
Old 03-13-2002, 03:21 PM
re separation: I'd have blamed it on insufficient spring force to produce the desired valvetrain acceleration, but your description seems qualitatively adequate. ((dM/dt actual)<(dM/dt required) instead of (M)>(M controllable)) Of course, that probably counts as being anal.
re valve bounce (I): interesting. I never paid much attention to what happened after a separation event, because I've always focused on preventing the separation in the first place. The one thing that I'd have to point out, though, is that the compression and rarefaction of the valvetrain will often be the cause, rather than the result, of valve separation. There are plenty of instances that come to mind where the valve spring could provide sufficient force to produce the required kinematic acceleration profile, but the "slinky" vibration of the system launches the follower anyway (or launches the rocker off of the pushrod). For separation control, I generally just look at % contact time over the nose vs rpm, and if % contact falls below about 95% at "rated overspeed" I go back for another look at how to improve control. In a "racing" type application, greater separation is acceptable. I've often contemplated how to design a "catcher" profile, but I've never had an appropriate application for one thus far.
re valve bounce (II): it has been my experience that kinematic closing ramp velocity has little bearing on actual seating velocity of the valve when the valvetrain gets "excited" (excessive vibration, loss of control). Picture a high-frequency, medium-amplitude vibration superposed upon the kinematic lift profile - if the vibratory amplitude is as high as the closing ramp height (and it's sometimes 5 or 6 times higher), the valve can close w/o touching the ramp, then re-open partway down the ramp, then close again, then open again, etc. In fact, it has been my experience that even with "negative lash," where the kinematic cam profile doesn't allow the valve to seat at all, the valve can still bounce repeatedly off of the seat after the initial closing event, if the valvetrain vibration is severe enough. Usually when I see seat bounce it's this kind rather than the other kind, but I'm sure the other kind happens too.
Old 03-13-2002, 05:23 PM
fritz_269's Avatar
Excellent and intresting points IvyMike!
dM/dt? I take it that M = momentum = mass * velocity?
So dM/dt = mass * dv/dt = mass * acceleration = Force.
The spring Force must be >= the force on the cam lobe = moving mass of valvetrain * acceleration profile of the cam lobe.
The idea of maximum 'controllable' mass is useful where the profile of the cam lobe is fixed, i.e. the acceleration is a constant. Thus we calculate the amount of mass that a given spring can control. Admittedly, this is a back of the envelope calculation, but it's really a useful parameter for us street racers that have to choose a cam out of a catalog (i.e. we pick our cam first to meet specs, then choose a combination of valvespring strength and valvetrain masses to meet our RPM goal.)
Interesting point about bounce (I) - wouldn't a good solution just be to move the natural frequency of the valvetrain significantly above (or maybe even below) the excitation frequencies of the cam profile? Or to add damping to the system? Does this still happen a lot with hydraulic lifters/rockers (which provide some damping)?
Great point about bounce (II) - I never really thought about continuous higher order vibrations in the valvetrain. What is the primary cause of that? Large-scale camshaft vibration? When are you most likely to see it? Can you actually use these vibrations to help cancel valve bounce, i.e. carefully design a system so the higher order harmonics are 180 degrees out of phase with the fundamental? Or are they usually completely uncontrollable?
3y30wnj00 - nope. I design microchips for a living. IvyMike is a real-life automotive engineer though.
Old 03-13-2002, 09:09 PM
Good. I figured you'd be able to keep up, so I didn't bother breaking that one down for ya.
I'm with you for this part:
"The spring Force must be >= mass of valvetrain * acceleration profile of the cam lobe" as long as you meant "effective mass of valvetrain" since the parts are moving at different velocities depending on which side of the rocker they're on, and hence have differing contributions to "effective mass."
The part I'd disagree with:
"the force on the cam lobe = moving mass of valvetrain * acceleration profile of the cam lobe." The force on the cam lobe is 0 if the spring force is precisely equal to the force required to keep the valvetrain in contact with the cam lobe (think accelerated free fall).
wouldn't a good solution just be to move the natural frequency of the valvetrain significantly above the excitation frequencies of the cam profile?
Yep, that's a great solution, and it's the best way to make sure you don't have any vibration problems in the valvetrain. Unfortunately, it's not always possible (and there's no such thing as an easy problem). The best way to increase the natural frequency is to shorten the distance from the cam to the valve. Overhead cam valvetrains have higher natural frequencies than pushrod valvetrains, and direct-attack OHC valvetrains are better than the rocker variety. Unfortunately for cam&spring designers, many engines still use pushrods (and use them to the absolute limit, I should add).
An interesting suggestion about damping. Unfortunately, there are few places where you can practically add damping, since the motion you're trying to get rid of is not the motion with respect to "ground." Using a material with high internal damping would be an alternative, but last I checked magnesium was still pretty pricey. :alien:
re: hydraulic lash adjusters - you've found a weak point in my knowledge on the subject. I've very limited experience with HLAs, so I hesitate to answer this off of the top of my head. What I can say about them is that they're HEAVY and very flexible (both of which are bad, of course). They do have the nice feature of eliminating the need for mechanical lash. In the few systems I've designed w/ HLAs, they made things ever-so-slightly worse. I will likewise hesitate to extend a generalization about their performance in all applications, as the few situations where I've used them have been anything but typical. Tell ya what - ask me again this time next year. By then I'll probably have had a couple more chances to mess with HLAs, and I'll have a better feel for how they influence systems in general.
Here's an interesting mechanical design problem for you to mull over:
"Design the highest natural frequency pushrod possible with a length of 100mm"
* Use a generic tube of iron (or steel, if you prefer) for the pushrod. To keep this simple, don't worry about the end caps.
* Use a simple "mass on a spring" system to represent the pushrod for the purpose of calculating natural frequency. Support the entire mass of the pushrod on a spring with stiffness equal to the column stiffness of half of the pushrod. Remember, w = sqrt(k/m) for this system.
* Remember that the formula for stiffness of a column is k = E*A/Lh, where E is young's modulus (use 170 GPa for iron or 207 GPa for steel) , A is cross-sectional area, and Lh is length. Don't forget to use Lh = overall length / 2, since we're only using half of the pushrod for the stiffness calc.
* The mass of the column is d*A*Lt, where d is density (so much for greek letters, eh?), A is cross-sectional area, and Lt is total length. Use 7200 kg/m3 for iron (or 7850 kg/m3 for steel).
* Don't worry (for now) about the load on the pushrod, or buckling, or any of those other pesky things that'll slow ya down.
See if you can beat 1536.6 rad/sec for iron, or 1623.9 rad/sec for steel. I used ID = 5mm, OD = 10mm for my tubes (both iron and steel) if you'd like to know. Another thing to look at once you've found your best frequency is what crankshaft order does this correspond to? For my (iron) pushrod, here's what I get: 1536.6 rad/s = 244.6 Hz = 14763 cam cycles/min =
29347 rpm order 1
5869 rpm order 5
2935 rpm order 10
2257 rpm order 13
Since cam profiles will often have excitation orders as high as 7 or even 10, my stated pushrod design would likely vibrate quite a bit within the running range of a medium speed engine. Consider that the valvetrain as a whole will likely have a considerably lower 1-node-mode natural frequency... I think you'll see why I say it's a difficult task.
re higher order vibrations cancelling bounce: yes and no - at some operating speeds, you can get a valvetrain that's totally in control with superb seating velocities. Bump the engine speed up or down a notch, and suddenly you'd be "in-phase" again, and back in the frying pan. For a fixed-operating-speed engine, cancellation could be a useful strategy. For the more common applications of engines, it won't work (the frequency of each excitation order varies linearly with engine speed, while the components' preferred frequencies remain fixed).
Yep, I'm an automotive engineer (of the mechanical sort). Many EE and CSE and Controls-E types would probably remind you that being a computer chip designer doesn't preclude being an automotive engineer.
Cheers.
Old 03-13-2002, 10:37 PM
higgimonster's Avatar
higgimonster higgimonster is offline
That is quite a post! I was following and understanding everything untill you started talking the problem at the end. That is pretty crazy stuff, but someday (hopeful) I will know how to do that stuff. I am currently studying for a degree in ME (automotive focus) at Rochester Institute of Technology. I have a couple off topic questions and a couple on topic questions.
Where did you go to school?
What is your feild of expertise? (or favorite area of auto engineering)
Any advice for a budding Mechanical Engineering?
Now back on topic:
Would the same frequency occur when using servos for valve actuation (similar the the Seimans/VDO system if I rember corectly)?
As far as I know from physics is that if the spring is compressed at all it will apply a force on the cam lobe. If you meant the total force of the spring/lobe system at that given moment is zero because of a lack of acceleration it makes a little more sense.
This is definetly the weirdest path I have seen a thread take; from "should I match brands for cam/valves?" to extremly technical discussion of valvetrain dynamics. Cool
mivec engine internals jerzralliart Lancer 1 11-23-2004 08:07 AM
Best place for engine internals? gsr916 Integra 0 10-23-2004 11:33 AM
Engine Internals LSfrankenstein Integra 8 10-09-2004 01:26 AM
Engine Internals Monster_CiviC_Guy '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 04-03-2004 03:48 PM
shopping for engine internals UncleMeat777 3000GT/Stealth 1 12-18-2001 08:39 AM
