Old 01-18-2005, 08:41 PM
tmiller0399 tmiller0399 is offline
95 Caravan won't shift into reverse
I have a 95 Caravan 3.8. Trans was working perfectly and suddenly it will not go in reverse. All forward gears are still working normally. I cannot find any other posts with these symptoms. It make no noise to indicate that it is doing anything when shifted into reverse.
Any ideas? Could it be the solenoid pack? Should I try changing fluid and filter and "wiggling" all connections to the trans?
any help is greatly appreciated.
Tim
Old 01-18-2005, 11:21 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 95 Caravan won't shift into reverse
new tranny fluid never hurts; do you have any check engine lights on? Any abnormal sounds, vibrations, etc.?
Old 01-19-2005, 05:32 AM
Re: Re: 95 Caravan won't shift into reverse
No check engine light or sound. Driving forward seems perfectly normal.
Old 01-22-2005, 05:31 PM
Re: Re: Re: 95 Caravan won't shift into reverse
Nobody else have any ideas? I hate to bring it into the shop for something I can check/fix myself?
Old 01-23-2005, 12:27 PM
HiRez_L HiRez_L is offline
Did you try changing the fluid?
Old 01-23-2005, 12:48 PM
not yet. Do you think fluid alone could cause it? I was going to try changing the solenoid pack at the same time.
Old 01-23-2005, 02:10 PM
Well, fluid could fix it, and if it does, you'll save the money for a new solenoid pack. On a '95, make sure when you flush and change the fluid, you use only Mopar ATF+3.
