Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-18-2005, 05:02 PM
swarrenpaid247 swarrenpaid247 is offline
lossing accelleration when
Up hill it loses accelleration.
Hard to start when cold.
Old 01-19-2005, 12:20 AM
biggbabysweetz1's Avatar
biggbabysweetz1 biggbabysweetz1 is offline
first any vehicle will lose speed when going uphill when either A you have cruise control on or B you keep the pedal at the same place however if you have acceleration problems when you floor it going uphill it may be time to change oil, airfilter, spark plugs, plug wires, and your remaining ignition system. i could provide a better response if i knew a little bit about your GMC like engine size and intake type(ex. TBI, DPI, carbuerated etc) the cold starts and acceleration are a combined problem and from what i can tell it is most likely a faulty ignition module. thats the problem i had with my suburban - replaced my ignition system with an MTI economy model and not only did i increase my mileage about 3 miles a gallon i got about 20 more horses and 40 FT/lbs of torque
Old 01-26-2005, 02:51 PM
Re: lossing accelleration when
1992 GMC Jimmy 4.3 v6 vortec. Changed the fuel pressure regulator, was still hard to start, now will not start.
Old 01-27-2005, 02:13 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Can you stop being so cheap on the details.
How can you expect us to help with little to no information.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-16-2006, 03:00 AM
lol i realize i haven been here for almost a year but hopefully youve got e-mail notification turned on
from the sounds of it your fuel pump is out.
you can check that the safe way or the dangerous way
first the safe way, replace your fuel filter and prime it before you start it, turn the key to the on position without starting it. if you hear a noise that sounds like your cd-rom opening then your fuel pump is not out
dangerous way replace your fuel filter and keep one of the lines off turn the key on if gas sprays out its good. i cannot be held responsible for any injuries caused by option number two, but can be very effective for checking your fuel pump
Suck squeeze
Bang Blow
Old 01-19-2006, 05:06 PM
Slow_n_ez Slow_n_ez is offline
Good susgestions about the fuel filter which is the cheapest way to start off first... My 2000 Jimmy was doing the same as you described but changing the filter didn't work for me .. Mine involved having the cadilic converter replaced .. I guess it was plugged up so replacing it gave me back the power to climb hills again ..........
Old 01-19-2006, 08:55 PM
Awesome point, i knew i was forgetting something
Suck squeeze
Bang Blow
