Old 01-18-2005, 03:41 PM
genlee genlee is offline
Diagnostic Codes
My 2000 Tuarus Check engine light came on recently. My fiances father had a diagnostic machine made by "Snap-on" that covered cars to 2001. i had him hook my car up and it came back with the following.
System check incomplete
p - 1408 - EGR - Flow out of range
I then replaced the EGR valve and reset the check engine light. The next day the light came back on. We rechecked it and got the following.
P - 1000 (OBO - II) system check incomplete
p - 1116 - ECT - Sensor out of range
P - 1408 - EGR - Flow out of range
Can anyone PLEASE tell me what the problem with the car is? It still runs fins but does seem to have a VERY slight studder on occasion, especially at idle, but otherwise still runs fine.
Old 01-18-2005, 04:46 PM
Banjoman10 Banjoman10 is offline
Re: Diagnostic Codes
Pls. read replies to posting #37 "SES light coming on"
Old 01-18-2005, 04:52 PM
fry628's Avatar
fry628 fry628 is offline
Read the values on the dpfe sensor and see what it says, it should be around 1.14 volts. If it's not them it's telling the computer that the egr is faulty. The ect problem could be that it's low on water.
Certified Ford tech for 10 years
Old 01-18-2005, 06:08 PM
I am not unfamiliar with cars, but i do not know what the ect or dpfe are, where they are or what they do, could you explain?
Old 01-18-2005, 11:15 PM
fry628's Avatar
DPFE(delta pressure feed sensor) reads your exhaust. Look at your exhaust and you'll see two rubber hoses coming off your egr exhaust hose going to a sensor that is mounted to your intake. ECT(electronic coolant sensor) Look close to your thermostat and you'll see a sensor with two wires that measure the temp of the coolant and if the coolant is low it'll read out of range.
Old 01-19-2005, 04:49 AM
is there a way to test these without replacing them? If not, can i purchase them from the dealer and install them myself or are they a complicated intall? any idea about what they cost? and THANKS so much for all the help you have already provided
Old 01-19-2005, 10:33 AM
fry628's Avatar
They are really easy to replace but beware that the two black rubber hoses that go to the dpfe are not vacuum lines. They are special hoses that resist heat and can only be purchased at the dealer. They might split when you try to remove them, Keep in mind that this is only a guess and the only way to be sure is to use a scan tool and get the values.
Old 02-08-2005, 05:32 PM
Update
THANK YOU ALL, i checked the water level in the overflow and it was low, i filled it, and did in fact replace the DPFE valve. I did have to purchase a new hose for the larger outlet on the new valve due to its different configuration, the larger port was molded farther away and the old tube would not reach. I then reset the codes and have had a week of no check engine light. THanks for the information.
