Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-18-2005, 01:58 PM
hulkmn069's Avatar
hulkmn069 hulkmn069 is offline
Arrow Govenor pressure code with erroneus shifts
on my 99 i'm getting the trans gov press code p1757 and it's not been shifting correctly between first and second. I am wondering is the govenor and it's components bad and if so how much should i be paying to get it fixed... i'd do it but i'm afraid of auto trans.
Old 01-19-2005, 04:57 AM
Cam7 Cam7 is offline
The problem could be the pessure solenoid or pressure sensor could aslo be the govenor. You have to drop the Trans pan to get at the solenoid or sensor. You will need a manual if you are going to do it your self. My guess is the sensor and probally 2 to 300 at a Trans Shop.
Old 01-19-2005, 08:01 AM
hulkmn069's Avatar
Re: Govenor pressure code with erroneus shifts
thanks for the reply i went to a shop and already the first thing he said was 2200 for a rebuild so the quest goes on.
Old 01-19-2005, 08:24 AM
1BADGTO's Avatar
1BADGTO 1BADGTO is offline
Yeah, I've heard the EXACT same thing
I don't know how similar a 99 is to my 95 but I just went through the exact same experience. My 1-2 shift was messed up, shops say I need a rebuild, I do more research, decide to swap out my Governor Pressure Solenoid and Transducer and now my trans is shifting back to normal. I did the swap myself but I've also been tinkering with cars for 20 years. It's a very easy swap but if your not comfortable, you might buy the parts from the dealer then go to a shop, tell them you only want those parts changed out and to give your old parts back to you. You might also give them the MOPAR fluid to refill your trans with. My transducer and solenoid ran $300 but your 99 parts might be cheaper. For reference my trans is a 42RE.
Chad Warkentin, McLoud, OK
1998 Jeep Cherokee 2dr 4.0, 2WD, 140k miles
1995 Jeep GC Laredo 4.0, 2WD, 365k miles (sitting behind barn now)
1964 GTO
2006 GTO - Sold
1977 Chevy 1Ton CrewCab Dually, Full Roller 468 - FAST Farm Truck!
1972 Harley Davidson
Old 01-19-2005, 08:40 AM
1BADGTO's Avatar
In case you are wondering......and remember yours may be totally different......I dropped the pan, then the filter. Disconnected the wiring harnesses from the transducer and solenoid. In my case, the solenoid and transducer are mounted to a cast/machined aluminum housing. Housing is held in by both hex and torx head bolts. The housing assembly drops straight down. You can now see the clip that holds in the transducer in the side of the housing. The solenoid just slips in from the bottom. I cleaned my pieces with electrical cleaner (no residue) and sprayed the mating area on the trans. replace the housing, torque the screws and hook up the wires. Install new MOPAR filter and gasket and refill trans. It's a messy job but I knocked it out in about an hour and most of that time was letting the fluid drain off the valve body. Good luck!
Old 01-19-2005, 10:57 AM
hulkmn069's Avatar
thanks for the info i am definately going to look into it more i am going to try to find a trans book on this and possibly do it my self. i am not incapable by any means i am just inexperienced in the trans dept.
Old 01-19-2005, 11:36 AM
mx52nv's Avatar
mx52nv mx52nv is offline
how much are the parts for this and can you get them through NAPA etc. or just the dealer??
current rides:
1990 Turbo Miata
lifted and locked 96 Grand Cherokee with other toys under the hood
retired rides:
1996 Eclipse GSX
1991 Stealth
1991 Porsche 993 C2
1988 BMW 520i
Your SUV isn't a Jeep, and my Jeep isn't an SUV....
SCCA, where you actually learn to drive
Old 01-19-2005, 02:55 PM
1BADGTO's Avatar
I bought mine through the dealer and was $300. I'm sure aftermarket is cheaper but this is a job I want to only do once. I've seen these parts on eBay stores for a little less than the dealer but I don't know if it is an OEM part or not. My parts from the dealer came in sealed baggies with parts soaked in tranny fluid.
Old 01-19-2005, 03:16 PM
mx52nv's Avatar
hey, can you post part numbers as well, thanks
current rides:
1990 Turbo Miata
retired rides:
1996 Eclipse GSX
1991 Stealth
1991 Porsche 993 C2
1988 BMW 520i
Old 01-19-2005, 03:45 PM
JUSTJEEPS JUSTJEEPS is offline
Do not use aftermarket solenoids,the suck!!!!!!!
As for a rebuild if the trans has large amounts of metal in it the new solenoids will fail soon due to the fact the transducers and solenoids are magnetic and pick up metal.
AT JUSTJEEPS WE REPAIR JEEPS FOR A LIVING,NOT FOR FUN.
Old 01-19-2005, 07:22 PM
glass glass is offline
also.... most important...it cost me $700.00 to find out that an independent trans OH shop used a metal retainer on the transducer and gov solinoid, it grounded out the expensive parts to junk right off the bat , and he did this 3 times ..went to the dealer and he said the retainer had to be non metallic , and that you do not put steel parts in the electronic transmission, the car runs like a young pup now ... lesson learned the hard way
Old 01-20-2005, 06:24 PM
hulkmn069's Avatar
well all i know is that this is going to be a bigger headache than i was hoping for ah well
