Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 01-18-2005, 12:37 PM
alexd4488 alexd4488 is offline
Help W/ Electrical Please
Hi,
I have been having some problems with my electrical system and I am open to any suggestions. A couple months ago I put in a Pioneer head unit, and my car worked fine. About a month ago i put two 10" subs in w/ a 500W Max amplifier and the lights started to dim along with the beat. I then installed a Tsunami 1.2 farad cap, and the problem is still a problem. I have a feeling i need a hi-amp alternator, but that is the reason I bought the cap, to avoid a new alternator. I am open to any suggestions to try and fix this problem.
Thanks!
Old 01-18-2005, 07:37 PM
JDPascal JDPascal is offline
Re: Help W/ Electrical Please
I'm no expert on stereo systems but I would install a second battery with an isolator immeadiatly before the positive post.
A high amp alternator will help some with a single battery but the ideal is a second battery with a big alternator.
JD
Old 01-18-2005, 11:11 PM
arctycfox arctycfox is offline
Send a message via AIM to arctycfox
Re: Re: Help W/ Electrical Please
JD
I am a proffesional car audio installer, and believe me.....a second battery will only worsen your problem. A second batter requires more charging power and therfore will definetly need a bigger alternator. A capacitor will improve you instantaneous current draw, nut not if there is an existing problem with you charging system. At this point, if the cap didn't help, you're looking at a new alternator or primary battery. NOT a second one. Most likely an alternator. And since you're getting a new alternator, why not upgrade to a higher output one.
Old 01-18-2005, 11:31 PM
Makes sense to me......Now that I think more about it.
Second battery might help for a while till it is drained a bit. Then more problems.
I did say "A high amp alternator will help some with a single battery but the ideal is a second battery with a big alternator."
What is your experience with the second battery instalation??
Thanks for the clarification to the thinking of my tired brain.
JD
Old 01-19-2005, 06:47 AM
gtmud gtmud is offline
What about double checking your grounds? YOu might try running a seperate wire to have a good definate ground. Also, might look into the Optima batterys to handle your system demands and the vehicle demands.
Old 01-21-2005, 06:16 PM
thanks
Thanks a lot,
I checked my ground and it turns out that I didn't ground it very well. I regrounded it on a different bolt and that worked out for me.
