Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 01-18-2005, 12:18 PM
chubbybubba1 chubbybubba1 is offline
Shrockworks winch bumper
Come on! Hasn't someone put a winch on a Shrockworks winch bumper yet? I'm looking for what brand and model number you installed. I think I want a Mile Marker since it won't have a lot of use hopefully. Warn's are a bit steeper in price for as much as I'll use it. I just want to have it if I ever need it!
Old 01-18-2005, 05:41 PM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
Re: Shrockworks winch bumper
What's the question here? Get whatever winch you like that will fit, and go for it.
Old 01-18-2005, 07:27 PM
Cool
Is it as easy as you make it sound? The winch I want is the Warn 12,000lber. But I know that won't fit. There's quite a few to choose from. Just looking for what someone else has done with the Shrockworks so I home in on just a few choices between brands and more specifically model numbers.
Old 01-18-2005, 07:36 PM
I know someone with a Milemarker 12K electric in an ARB, so I'd figure the Warn ought to fit too.
Old 01-18-2005, 09:35 PM
I'm just trying to get a head start on my choice of a winch. I need to get the bumper on first then I'll understand your optimism better after seeing the mounting location.
Old 01-24-2005, 08:58 AM
ChuckH's Avatar
ChuckH ChuckH is offline
Have you asked Schrockworks what will fit? The winch mounts very close in front of the radiator to make the bumper shorter and give a better approach angle...that's all I know. I'd be careful about trying to go too big, since even if it will technically "fit," any tiny impact might drive it through your radiator. Anyway, contact Jim and ask him. He builds them so he should know, and he's a very friendly dude!
ChuckH
Old 01-26-2005, 07:41 PM
I e-mailed them a few days back and still waiting for a reply.
Old 02-11-2005, 01:13 PM
Sentra Styling Sentra Styling is offline
Send a message via AIM to Sentra Styling
Jim over at Shrockworks told me I should stick with 9500 or less to fit fine...
2002 Nissan Xterra SE Black
1993 Sentra SE-R Black
1994 Sentra SE-R Red
All SR20DE powered...
Old 02-11-2005, 02:31 PM
Did he tell you of a specic model # or brand?
Old 02-12-2005, 10:44 AM
Re: Re: Shrockworks winch bumper
Not at all he said either Mile Marker or Warn will work..They both have the same bolt pattern...I am tossing up between the two...but I might go with the Warn M8000.
Old 02-12-2005, 02:54 PM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
Re: Re: Re: Shrockworks winch bumper
I'd suggest dropping the extra cash and getting a 9000.
Xterra4x4.com and the Xterra Offroad Webring
Old 02-14-2005, 10:49 PM
For sure. I'll go with the 9000LB OR 9500LB. CAN'T DECIDE ON WARN OR MM. I WON'T USE IT ALL THAT MUCH, SO ON ONE HAND THE MM WOULD SAVE $ IN THAT INSTANCE. bUT THEN WITH A WARN YOU'LL KNOW IT WILL WORK WHEN YOU NEED IT MOST.
Old 02-15-2005, 03:54 AM
XTerra Guy
Well that's pretty much it, isn't it? How much is the cost savings versus a body panel, a mechanical part, a tow, hiking out of the woods? My winch has recouped it's cost several times over in potential damage and extraction. Plus it's a great tool that often comes into play when offroading. You can't compare the directional, constant control of a winch over a tug-strap, even though I use both.
So do you want the one that's the cheapest?
Old 02-15-2005, 10:37 PM
Your right. I'll buy a Warn.
Old 02-17-2005, 09:57 AM
But what makes MM the inferior winch?It really doesn't take much to produce a winch and both companies have been making them for years...
