Old 01-18-2005, 11:04 AM
Special_Ed_1971 Special_Ed_1971 is offline
Send a message via Yahoo to Special_Ed_1971
99 Z24 Manual Trans Help
Over the weekend drove to Chicago with a friend to pick up her kids, about a block from our destination the car started making a grinding noise. When we got in front of the house the car stopped moving. When I disengage the clutch and it's just the enginee running it sounds fine, but when you reengage any gear to try to move it sounds like a grinder just grinding up metal. The car wan't being driven hard and has 124,000 miles on it. I am just assuming the trans gave and I need to replace it, but i would like some opinions mainly because I am not very repair orientated and need some guidance.
Thanks in advance everyone.
--stranded
Old 01-18-2005, 01:14 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: 99 Z24 Manual Trans Help
maybe is just needs to be serviced.. like flushed and refilled if its never been done. Also check your clutch fluid resovior..
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 01-18-2005, 02:04 PM
well, all fluids were checked before I left to go up there and there were all full when I had to leave it. I just think it failed, in which case, I have to go find a truck and trailer and tow it back down here.
Old 01-18-2005, 02:22 PM
Lifted GMT-360!
Was it just hard to put into gear and sounded like you were makin sasuage? How far do you have to push the clutch to the floor before it disenguages or enguages out? There is a few possibilites, lets hope its just the clucth and not the tranny. If it stays in gear and its only malfunctioning while trying to be put into gear,, its more than less your clutch.
Old 01-18-2005, 02:43 PM
No, it goes into and out of gear just fine, it just won't move.....sounds like metal in a blender when you step on the gas with it in gear.
Old 01-22-2005, 03:19 PM
noshun's Avatar
noshun noshun is offline
Sounds like your pressure plate on you clutch has collapsed and the clutch plate isn't engagain at all. The pedal probably wouldn't go light as it hydrualic and the sound me be the fingers (springs) from the pressure plate having broken off and spinning inside the pressure plat and your thrust bearing (pilot bearing) has gone all the way though! I would say that was the problem right there!
I did you a picture!
This bits circled have probably broken off!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 01-23-2005, 12:20 AM
Unhappy
Great, sounds like I need to empty the bank account.....lol
Well, my next problem is getting it home from the city it broke down in...
Thanks for the help
Old 01-23-2005, 09:28 AM
noshun's Avatar
don't like to be the bearer of bad news but thats what I believe the problem to be.
