Old 01-18-2005, 10:41 AM
the.dude's Avatar
the.dude the.dude is offline
rear struts
About how many miles can a person get out of original rear struts?
Old 01-18-2005, 10:53 AM
BIG-L's Avatar
BIG-L BIG-L is offline
You have a 98,id say its time to replace them.Factory original struts dont last very long.Made a big difference when I changed mine @ 61,000 and the car rode so much better,but then again I went with the GMPP konis.Alot of people have went with the KYB struts and there is a site you can get a set of 4 @ 170.00
~Larry~
ClubGP Member 6530
Since 2001
Old 01-18-2005, 11:02 AM
the.dude's Avatar
I changed the fronts about a year and a half ago. I didnt really notice much change.
The reason I'm asking is I have a vibration at high speeds. I feel it mainly in the floor and notice it a lot more with backseat passengers.
Old 01-18-2005, 11:12 AM
BIG-L's Avatar
Have you had the tires balanced lately?? I dont think it would be struts causing the problem.It sounds like a bad trailing arm or other rear suspension component other then struts.
~Larry~
Old 01-18-2005, 11:20 AM
the.dude's Avatar
My tires have been balanced several times. Alignment is good. Other rear suspension stuff I do not know about.
Old 01-18-2005, 11:28 AM
BIG-L's Avatar
Re: rear struts
Sounds like you should get it on a lift and have the rear suspension component's inspected,before replacing the rear struts.
~Larry~
ClubGP Member 6530
Since 2001
Old 01-18-2005, 11:33 AM
the.dude's Avatar
I've actually got it up in the air now, what am I looking for? Just bends or abnormalities?
I've been getting a bad vibration when I bottom out in a valley on a highway, or during fast acceration. Worst is 65-75mph.
Thanks so much for the advice!
Old 01-18-2005, 11:55 AM
BIG-L's Avatar
Yes...Just bends or abnormalities?
Are you sure it's from the rear??? We also have a problem with our CV/axels causing a vibration during acceleration.Just a tought.
~Larry~
Old 01-18-2005, 01:48 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: rear struts
Larry, I think you are going to have a hard time talking him in anything. I think he is set on what is wrong with it. Might want to let him change the rears and then he will listen to what you say.
The thing is, everything you are telling him to CHECK won't cost him a dime. And is more then likely what he needs to do.
Good luck
~Larry~
Old 01-18-2005, 09:33 PM
the.dude's Avatar
yeah... I am focused on whats wrong with it. Should I be sensing sarcasm? I just wanted all the info I could get before heading to the shop. The reason I was concered about the struts was my high miles 130k and the difference I notice with a load in the car.
I doubt I tear into the rear end anytime soon anyway. I'm going to check out the trailing arm, but I'm cashed out. I just got finished replacing what felt like most of the front, and now I have a horrible chatter coming from the belt. When it rains, it pours
Old 01-19-2005, 05:57 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: rear struts
I think the rear struts are probably in need of being changed due to the 130K miles on the car. But I don't think the vibration you are feeling is due to the struts. Big-L is right in point out the CV joints since the symptoms of one starting to go bad is a vibration at speed. Replace the struts first, if that doesn't change the vibration then go with the CV joints as they are more expensive to replace than the struts.
