Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 01-18-2005, 09:43 AM
capnb capnb is offline
Keypad Code Location
I am trying to locate the factory keypad code on a 2002 Sport Trac I just purchased...can someone help me?
capnb
Old 01-18-2005, 12:38 PM
landyacht's Avatar
landyacht landyacht is offline
Down under the steering wheel on the under-side of the dash, there ought to be a black strip of metal. On that should be the key-code and/or the keyless entry code.
The keyless entry code is for the keypad most likley, but to make sure you can drive into your Ford Dealer and ask them to give you the PIN number if this code doesn't work by running your VIN. Don't let them charge you for it either, some shops can be real jerks about just helping a guy out.
In any event, i hope that helps you man.
Mine's an '82 Pontiac Parisienne 4-door sedan!!
- 305 cu inch (5.0L) small block V8 w/ 3spd auto
- 4 barrel carb w/ single exhaust
- No catalytic converter, no posi-trac
NEVER LOSE FAITH IN THE BOAT!!
Old 01-19-2005, 12:17 PM
curttrax curttrax is offline
Re: Keypad Code Location
[quote=capnb]I am trying to locate the factory keypad code on a 2002 Sport Trac I just purchased...can someone help me?
I am also looking for the 02 door code , if you find out where it is let me know please. , because ford want $95 for the search.
Old 01-21-2005, 10:17 AM
2001Sport_Traccer 2001Sport_Traccer is offline
Re: Re: Keypad Code Location
[quote=curttrax]
I have an '01 (other threads have suggested they eliminated this practice in later models, but it's worth a check!), and I found it on the computer module located behind the plasic wall behind the rear seats, between the two tiny access panels where your tire jack is. It was on a sticker on the lower right section of the computer module, 5 digits. Tough to get to, but I read it without a mirror.
$95 dollars, give me a break. Hope this hels you as much as it did when I found out how.
Old 01-22-2005, 10:27 AM
Thanks to all who responded to my plea for help. I have had quite a few inputs as to the location of the keypad code location. I have concluded that the locations have changed through model years and as for my model 02, it appears that it might be behind the passenger side's airbag....a place I am not going....looks like I'll have to get it the expensive way.......dealer's choice.
capnb
Old 01-26-2005, 10:28 AM
TomShick TomShick is offline
Touchpad code
We bought a used 99 explorer and can't find the code.The ford dealer said it is in a card in the book(which we did not get).They can hook the computer to it and get it and will cost us $25.00
Old 01-27-2005, 09:58 AM
punmaster7 punmaster7 is offline
1998-2000 Explorer and Explorer Sport keypad codes are on a label attached to the computer module (facing outward) located in the rear left inside fender panel accessible by the jack cover panel. I pulled my '99 module bracket until I could read the number. A flashlight is a must and a mirror might help too!
I know someone who rebuilt a 2001 Sport Trac and he found the code right where 2001Sport_Traccer said it was.
For those interested, Northern Tool Inc. has the OBD code readers starting at $135. At $95 a pop, wouldn't take long to pay for it, whatever the problem! It's also cheaper if you know someone who has one!
Old 01-27-2005, 03:49 PM
AutoZone has them for $85 on up--depends on the ability to reset the computer and dignose things down to the molecular level of the problem. I've had mine read once to HALFway solve a IAC problem, and that was $70 right there; I'm kicking myself for not having gotten one because that was half the cost of one right there, and I'm BOUND to use it again. Live and learn.
Old 01-28-2005, 01:15 AM
cbreeze191 cbreeze191 is offline
Here is a link with pictures for a 2002
http://s88853021.onlinehome.us/explorer/keypadcode.html
taken from autoforum post
http://www.automotiveforums.com/vbul...ghlight=keypad
Hope this helps the pictures are awesome.
Old 01-28-2005, 08:43 AM
Oh no! I'm in love! ToolTopia has the AutoXray 6000 for $466 and free shipping! And I have my income tax refund coming, too! Anybody need their computer read, reset, graphed and printed??
Sorry, running a bit off topic.
Old 01-29-2005, 07:45 PM
Re: Re: Re: Keypad Code Location
Good call--once could make the money back in a matter of months by offering its service out for a quarter of the cost at a retail shop. Thanks! You may have just made my Christmas budget!
