Old 01-17-2005, 11:04 PM
juicehedgehog juicehedgehog is offline
Send a message via AIM to juicehedgehog Send a message via MSN to juicehedgehog Send a message via Yahoo to juicehedgehog
excuse me if this double posts... but I have a problem
That's why I'm here. I have a 1983 F-150 5.0 litre. I parked it one night (a few days ago in fact) and it was running fine. That night got extremely cold (it does that here in Canada ;p) and it wouldn't start the next morning. I figured it was just cold. A can of ether later, and a dead battery, we still had a dead truck. I thought the lines were frozen, so I waited for it to get close to freezing, and tried again. Still no luck, took off the air cleaner, looked in, and the fuel was flowing freely. I have spark on all cylinders too... I replaced the distributor cap, coil wire and plug wires, as well as two plugs (I broke them during inspection ^.^ just in case. Still nothing. The solenoid and starter wire overheats very quickly, I burned my finger on the stupid thing. There's one more symptom, though I don't know if it's related. I have a small emergency light that plugs into the lighter socket, I was using it to see the night the truck died. I tried to use it again today, but the light didn't come on and the wires got super hot... it may be related, but how?
Anyway, that's my story. I really appreciate any help you guys can give me... I need a vehicle for a new job that I start next week, this is very important that I get this thing running again. Thanks!
Old 01-18-2005, 12:43 PM
landyacht's Avatar
landyacht landyacht is offline
I'm in Canada... i know how you feel!
You already said that the starter is good? So when you boost the thing and go to turn the motor over does it turn or make a noise or is it just dead?
I'm assuming it's just dead...
I think other then the starter is the possibility of the alternator having gone. It went in my car just *snap* like that when i was driving down the road with no warning.
Finally, it's rare but not impossible, the motor siezed?? If you canturn it over that's not the case. After a few days i imagine the thing isn't flooded anymore....
Excuse my randome thoughts, but check those 2 things and see if you can't truly determine the issue.
Mine's an '82 Pontiac Parisienne 4-door sedan!!
- 305 cu inch (5.0L) small block V8 w/ 3spd auto
- 4 barrel carb w/ single exhaust
- No catalytic converter, no posi-trac
NEVER LOSE FAITH IN THE BOAT!!
Old 01-18-2005, 04:40 PM
fry628's Avatar
fry628 fry628 is offline
Re: excuse me if this double posts... but I have a problem
An 83 I believe has a ignition module on the side of the distributor that sometimes goes bad and there is a sensor inside the distributor that goes bad. Both thing control the timing of the spark (i.e. you can get a spark and still no start). The only way to replace the sensor inside is to replace the whole assembly. Sorry!!!
Certified Ford tech for 10 years
Old 01-18-2005, 07:40 PM
thanks for your replies, Landy and Fry... the motor does indeed turn over, there is spark, and fuel... It's definitely not the starter. Oi, I really don't want to replace the whole distibutor. But if that's what it comes to... another visit to Canadian Tire it is! ;p
