Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 01-17-2005, 09:55 PM
I-Eat-Civics I-Eat-Civics is offline
Send a message via AIM to I-Eat-Civics Send a message via MSN to I-Eat-Civics Send a message via Yahoo to I-Eat-Civics
mr2 questions
my friend just bought an mr2 and it got beat by a stock spec V. there has to be something wrong with it. It runs fine and he drives better than me. Is there maybe a way the turbo was turned down? cuz i mean even if it was ragged on bad it shouldve still beat the spec v. and how many lbs of boost can u push on a stock mr 2. IT's a 1991.
The 91 LS no Longer Lives www.RIP91TEG.piczo.com
__________________________________________________ ___________
1995 Acura Integra GS-R:
Blown Motor Waiting for swap
Old 01-18-2005, 01:32 AM
ac427cpe's Avatar
ac427cpe ac427cpe is offline
Miata is always the answe
Send a message via AIM to ac427cpe
Re: mr2 questions
are you sure it's a turbo? and are you sure it's the fault of the car?
hello, i am Dan
No more project cars. I wonder how long that will last...
Old 01-18-2005, 05:43 AM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Re: mr2 questions
I test-driven some amazingly beat turbo MR2s that ran terribly.
As for your boost question, I would not go over 15 psi with the factory turbo. If you upgrade the turbo and make the necessary modifications to the rest of the system you can run a lot of boost. I am currently racing at 23-24.5 psi on a 100% original engine with 200,222 miles.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 01-20-2005, 09:06 PM
Re: Re: mr2 questions
well is it possible the boost is turned down, cuz i might be getting it. and its there a stock watsegate on them?
Old 01-20-2005, 09:08 PM
o yea and if its not the boost what can be done for them to run better cuz it only has 119 k
Old 01-20-2005, 09:24 PM
AF - Advisor
Re: mr2 questions
I've never heard of a turbo without a wastegate ... so yes, they do have a wastegate
The biggest place used MR2s lose power is the ignition. I suggest buying brand new TOYOTA cap, rotor and wires once a year. Get your self some new NGK copper plugs or the Toyota platinum plugs if you are not really modified yet.
I have seen MR2s down as much as 30 rwhp because of these parts.
I would also do a fuel filter, air filter and oil change and see where that gets you.
Stick a boost gauge in there so you know how much boost you are running.
It is possible that you are stuck in "low boost mode" which would only be 7 psi or so.
OEM boost should hit 11.98 psi, but under certain circumstance the ECU limits you to 7.
Old 01-20-2005, 09:31 PM
NSX-R NSX-R is offline
Re: mr2 questions
What kind of tires does the MR2 have?
Old 01-21-2005, 10:14 AM
what would make the ecu limit the boost?
Old 01-21-2005, 10:30 AM
AF - Advisor
Re: mr2 questions
*coolant temps to low
*ambient temps to low
*detonation (knock)
*others that I may not be aware of
I would also check to make sure the TVIS is opening up. If that does not open, you are only running on 4 intake valves per cylinder instead of 4.
Have you checked the codes?
What date is painted on the ignition wires?
I would really start there first.
Old 01-21-2005, 10:26 PM
TRD2000's Avatar
TRD2000 TRD2000 is offline
Re: mr2 questions
hi temps seem to do the trick too Jeff...
Who needs AWD? i feel inspired by the original 911 turbo, my car will have more rubber sqeezed in its ass than Annabelle Chong! and it will go down as one of the greatest rides in history!
Old 01-22-2005, 12:16 AM
Im JDM Yo's Avatar
Im JDM Yo Im JDM Yo is offline
Re: mr2 questions
Date? I thought 1998 meant 1998cc's.
91 Black MR2 Turbo
Project GT28RS is now officially under way!
http://www.Cardomain.com/id/EvilMR2
Live in columbus, OH? http://www.ColumbusStreetracing.net
>>>MR2 Online.com http://www.MR2Online.com
Old 01-22-2005, 02:15 PM
TRD2000's Avatar
Re: mr2 questions
ok, i'm hanging here, what exactly is a spec v? cause the only one i know it the gt-r skyline, if so there's really no surprises so it has to be something else right?
Old 01-22-2005, 05:52 PM
AF - Advisor
Re: mr2 questions
TRD2000, hi temps increases the probabilty of knock/detonation which is my 3rd bullet above.
The ECU does not limit boost pressure based just on high ambient/coolant temps ... you have to start experiencing knock first.
Old 01-22-2005, 08:37 PM
a spec v is a nissan sentra se-r spec v 2.5 l cvtc 6 spd with 175 hp and its a 4 door
Old 01-23-2005, 01:48 PM
TRD2000's Avatar
Re: mr2 questions
ahhh ok, got ya now, wouldn't have guessed that one! thanks civics!
I just knew when it got REAL hot it didn't get boost (observation) handy to know its knock not temp, Thanks Jeff
