Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-17-2005, 09:04 PM
tjgala tjgala is offline
1997 Dodge Ram Trans
I have a 97 Ram 4x4, 5.2L. If I drive like a grandpa it seems to shift fine. If I get on it a bit, it shifts fine thru 3rd, then jumps back into 2nd for about 3 secs, then back into 3rd, then OD. And then its fine til I come to another stop and it does it all over again. Any ideas?
Old 01-18-2005, 10:35 AM
littlebit's Avatar
littlebit littlebit is offline
1997 dodge ram transmission
My transmission was hesitant shifting out of second,I added a pint of TransTune made by Seafoam.Drove it last night at about 25 degrees outside,It shifted better than it ever has.This product can be added to your existing transmission fluid.If you use Lucas you'll have to change the fluid and leave out enough fluid to add the Lucas to it.They say both products are good.
Old 01-18-2005, 10:54 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 1997 Dodge Ram Trans
And a fluid change doesn't hurt either.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 01-18-2005, 10:59 AM
TorinoGT69's Avatar
TorinoGT69 TorinoGT69 is offline
Automotive Master
Send a message via MSN to TorinoGT69
Transmission is probably failing dodge trucks have are know for transmission failures.
Old 01-18-2005, 07:30 PM
lineguy lineguy is offline
Check that your T.V. cable is properly adjusted. It caused that problem with my 2001.
Old 01-21-2005, 10:54 PM
troy1 troy1 is offline
AF -Advisor
output sensor
Old 01-23-2005, 08:45 AM
Re: Re: 1997 Dodge Ram Trans
Originally Posted by troy1
output sensor
but then wouldnt a light on dash come on cuz its a sensor?
Old 01-23-2005, 11:01 AM
littlebit's Avatar
output sensor
A sensor would more than likely cause the engine light to come on.I had this problem and went to buy the sensor.They asked if the light was on,if it wasn't not to waste the money on the part because it would not fix the problem.I bought a can of SeaFoam and added it.Mine shifts like a new transmission,but i don't know what it will do tomorrow!
