Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-17-2005, 08:50 PM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
passkey system fault
i got that this morning when i got my car started, i've had problems with the car starting, it just would sit there no turning over, well I talked witha mechanic after replacing the starter, battery, and ignition switch and he says its the nuetral safety switch which I need to replace, its not that much but I was a little confused when the passkey system fault showed up. The tach and speedometer is also going haywire, but thats been like that for a while and I know its a ground problem with the tranny and the harness. so i just have to go find it, but any info would help.
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 01-18-2005, 04:09 PM
bugsas99 bugsas99 is offline
same thing happened to me
about 4 weeks ago the same thing happened to me. i had to have car towed to garage. the computer kept saying clean key wait 3 minutes. so i waited 3 minutes and nothing happened. anyhow they changed the resister in ignition and now everything is fine. total bill was 105.00 dollars. hope this helps. let me know what happens.
