Old 01-17-2005, 08:13 PM
wdy wdy is offline
dull headlights
I have a 97 s-10 2 door and the headlights do not shine very bright (old technology). I was wondering if anybody has ever put headlights from a 00 or newer onto a 97 to get better performance?
Old 01-17-2005, 10:43 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: dull headlights
find some 95 or 100 watt bulbs, will work out good
Old 01-17-2005, 11:27 PM
OverBoardProject OverBoardProject is offline
Banned
Re: dull headlights
Clean the grounds right up first, and if your not happy add relays, and Brighter headlights at the same time. That's the best that you can get then.
Old 01-18-2005, 12:25 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: dull headlights
How is your alternator?
Check the reading on he dash gauge? Is it reading above 14volts?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-18-2005, 06:13 PM
wdy wdy is offline
Re: Re: dull headlights
thanks for the reply's...the altermator is fine, the headlights are the kind were you unplug the whole headlight not just change a bulb and every replacement I get just does not light up the road very well
Old 01-18-2005, 06:31 PM
Banned
Re: dull headlights
Here in Canada even Canadian Tire has more powerfull lights for your truck, and a relay can be wired into any headlight's often making them brighter (even stock weak lights)
Old 01-18-2005, 06:32 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: dull headlights
How are you sure it is fine?
Old 01-18-2005, 06:51 PM
wdy wdy is offline
Re: Re: Re: Re: dull headlights
the guage reads 14 to 15, I have replaced the lights with sylvania silverstar, I know part of my proplem is I am comparing them to a 01 outback that lights the road up real nice. I was just hoping there was a way to get the same performance
Old 01-18-2005, 07:09 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: dull headlights
If you want brighter lights you will have to go with ones that aren't street legal.
Old 01-19-2005, 09:20 PM
xtrememeasures10 xtrememeasures10 is offline
Send a message via AIM to xtrememeasures10
Re: dull headlights
I have silverstars on my 97, w/ composite headlights, i know what you mean. Go on ebay they have a "HID conversion" I dont think its a true HID but there going to be as close as you can get without spending hundreds of dollars. Other wize Im putting a 98 front end on my truck w/ projector headlights and HID conversion kit on in a couple months. Ill let you know how that goes when i get that all set up. Sure its going to be expensive but it will be worth it in the long run. well good luck
Old 01-20-2005, 08:49 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
You can get true HID's here... http://www.hidexpress.com/index.asp?...ATS&Category=2
