Old 01-17-2005, 07:25 PM
btsstb btsstb is offline
Unhappy 87 Not Starting 3.0l V6
Car ran fine on Saturday but on Sunday would not start. Turns over fine but will not fire. Have already replace the coil due to no spark and still, no spark.
Does anyone have any ideas on what this may be? Need help!!
Old 01-20-2005, 04:14 AM
Holdinkson Holdinkson is offline
Question
The last time I had a similar problem, after beating my head against the hood a couple time, I decided to change the CONTROL MODULE which is mounted on the base of the DISTRIBUTOR. You will need a "narrow" deep 5.5mm to remove the two screws. The part will cost about $40.00. Make sure that you apply the heat shielding compound to the metal plate of the new one before installing it...
New question: Has anyone found a wire harness that allows you to reposition the CONTROL MODULE to avoid direct contact with a heat source?
Respectfully.
