Old 01-17-2005, 07:16 PM
agco85 agco85 is offline
90 Park Avenue heater fan problems
On my 1990 Buick Park Avenue the heater fans stays on high even after you turn the ignition off. I disconnected the wire from the fan motor when I had the car shut off. Then I turned on the ignition and it didn't come on. When I shut the car off again, it stayed on again.
I have tried 5 relays behind the glove box and none of them did the trick. Does anyone here know which relay or something else might be causing the problem and where the relay is? If anyone has a wiring diagram they can email it to me at [email protected]
Thanks
Old 02-06-2005, 12:54 AM
LONGJOHN LONGJOHN is offline
Send a message via AIM to LONGJOHN Send a message via Yahoo to LONGJOHN
Re: 90 Park Avenue heater fan problems
my 93 pa did that replaced blower motor control module $126.00 now it works right.mine was under hood against firewall passenger side under all the relays and fusesdown in tubing from fan motor if you don't have fixed yet. Good luck.
