Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 01-17-2005, 07:25 PM
tgbg tgbg is offline
Oil pressure problem (or gauge problem)
My -89 B250 (318 v8) has a strange problem. It started yesterday. At idle the oilpressure reads normal or sometimes a bit higher than it used to. When driving (rpm going up) the oilpressure drops very low but not so low that the warninglight comes on. After I noticed this yesterday I changed oil and oilfilter but the problem is still there.
Is it the oilpump or is the gauge or the sending unit for the gauge?
Anyone has an idea?
Old 02-03-2005, 12:53 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Oil pressure problem (or gauge problem)
Funky; does the pressure stay up if you rev the engine while sitting still, or does it drop the same way? If it drops, I'd think it was the sending unit or indicator like you think.
If however it stays steady, then it might be the actual oil pickup in the sump. Try backing up suddently (parking lot or something) and see if the pressure holds steady. If it does, then the pickup may not be working right.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 02-06-2005, 08:48 AM
Pressure drops if car is standing still and I rev the enginge. I was also thinking about the pickup because when driving if I let go of the accelerator and let the car roll, engine idling, the pressure does NOT go up until I brake as if the oil in the sump needs to be moved in some way.
I have been keeping my eye on engine temperature as well when driving but it stays normal. If it was not enough oil circulating should not the engine temp go up, at least some.
Old 02-06-2005, 10:16 AM
I'd start with the guage and sensor, test the voltage in and out (I don't know the specs) and see if they're working right. I haven't heard of pressure going DOWN when the engine is revved.
Old 05-06-2006, 08:46 PM
rumblefish73 rumblefish73 is offline
Did you find out what was wrong with your oil pressure? I have a friend with a 250 Ram Van that's got low oil pressure when in gear and idling. It gets worse when the a/c is on idling around 650-700 rpm. I have recommended my friend put a real old fashioned gauge on it. Do any of you know where the oil presure sender is on this 1996 Ram Van 250? It has the 318 motor.
Thanks!
