Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-17-2005, 06:20 PM
skorpi0n_sting skorpi0n_sting is offline
Removing Gauge needle
I'm trying to install white face plate for the gauge cluster, i don't know how to remove the needles(temperature, tacho, speedometer and fuel). please tell me how to remove the needles to install the new face plate.
(1996 Integra GS-R - Manual Transmission)
Old 01-17-2005, 07:44 PM
gsr916 gsr916 is offline
Banned
Send a message via AIM to gsr916
Re: Removing Gauge needle
your gauges should have come with a tool... pretty much it kinda lookes like a mini crowbar... one end has a slit in it and is at an angle to the rest of the tool.. u slide the tool under the gauge and the slit fits around the shaft that the needle is on and you do a prying motion 360 degrees around the needle. if you dont have the tool... it might be very difficult to get them off without breaking, but i imagine you could make it. if you dont have it, reply back ill take a picture of mine for you and you can make ur own.
Old 01-17-2005, 08:19 PM
can you please send me the picture of tool, i dont have one. is there any place where i could buy one.
Old 01-17-2005, 09:51 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Don't forget to lift the needle over the pin that it rests on and remeber where the needle stops. Then when you put them back on put them in the same spot. Most of the time the needle is straight down when it comes to a stop.
Old 01-17-2005, 11:35 PM
Banned
oh yea that is a good point lol. good luck gettin that lil pin out tho... i personally couldnt do it. the reason u need to get the pin out b4 the needle is because a certain point after the pin, the needle will come to rest naturally, and if u remove the pin you can see where that point is, so u can put the needle back on the same way it was before and your spedometer will work. as a precaution, i already knew my idle rpm and i went out and figured out rpms at certain mph... when i was done i had to recalibrate them lol took a while but its cool now. ill take the pic real quick and post it shortly
Old 01-18-2005, 12:06 AM
Banned
ok here it is
http://img.photobucket.com/albums/v625/gsr916/Tool.jpg
crazy... when i was doing this i had the craziest dejavu ive ever had.
Old 01-18-2005, 02:55 PM
whtteg's Avatar
Man that tool would have made mine a lot easier, I did not have a tool and had to use just my fingers to pop the needles off.
Old 01-18-2005, 03:06 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Ya i didnt have no tool either...wtf Matt. What brand is yours?
Old 01-18-2005, 04:28 PM
Banned
NR Automotive. what is the deal with LEDs u can put back there or somethin... someone was talking about them not too long ago. do they just plug in or what, it would be nice to have the illumination behind them a tiny bit brighter
Old 01-18-2005, 10:11 PM
thanks for the pic, let me see if i can make one or get one.
