Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 01-17-2005, 06:17 PM
Jasonnin Jasonnin is offline
Brake problem?
This might be a easy questions for someone, but I am not really sure what the deal is. I recently had the brakes fixed on my wife's 2000 Accent(About 3 months ago). I noticed recently that when the car is being used for the first time in like 24 hours or so.. after its cooled down, and I used it the brakes just work a bit odd. At first It seems to brake normal while I am stopping at usually that first stop sign, then during the same braking period, it seems to brake harder on its own. (while I keep the same amount of pressure on the pedal) It feels like it all of a sudden catches and it brakes harder by itself. Then it stops, and doesn't do it again at all. Till the car like doesnt get driven for a while. Say 12 - 24 hours. (Its cold here in MN, and seems to have started doing it while its been cold) But it has only done it ONCE per a driving session. Its happened about a dozen times. Its weird.. anyone have any clues what might be causing it? I haven't checked the brake fluid yet, I dont know if that could cause this or not. Any feedback would be greatly appreciated.
Old 01-18-2005, 02:31 AM
mazdatech mazdatech is offline
Re: Brake problem?
accent huh, how many miles on it? I would have to say im not to sure of your problem but i will tell u to check a cuple things.
1 Did they turn your rotors when the brakes were done?
2 do a visual are your rotors iced up in the morning? u said it was cold and it only happens once or maybe they are oxidizing(rusting, they salt the roads out thier dont they)
3 have you checked your rear brakes? the wheel cylinders leak like a rotting wood ship in high seas on those things
4 and last it never hurts to flush out your brake fluid and its easy dot 3 actually attracts a lot of moisture and should be replaced yearly for optimum braking.
let us know if this helps and the reason i ask about the milage is because the wheel cylinders may be warrentyable!
Old 01-18-2005, 02:51 AM
BodyKits's Avatar
BodyKits BodyKits is offline
Banned
Re: Brake problem?
check your fluid, if its low it will cause this, also check the pad wear, see the pattern in how it is wearing. this ushally tells you whats wrong. but it seems to me like the pads are just now getting into the breaking period with should have happend along time ago so i would check the above and see what is going on.
Old 01-18-2005, 07:07 PM
The car has 67,000 I have approx 3-4 thousand miles on the car since I had it fixed. And yeah they do salt the roads here in Minnesota. But it never did this EVER when the car was new. When its gets to at least 20+ degrees, I'll check the fluid. By the way, is there a procedure you have to use in order to check it properly? Or do you just lift the cap and look?
Old 01-19-2005, 04:23 AM
Re: Brake problem?
well likke i said remove the right rear drum and check your weheel cyl first. then maybe flush your brake fluid if it gets down to 20 degrees and their is moisture in your llines then that is no good especally at that coldness check all then repost dont be laZY
Old 02-11-2005, 02:42 PM
PhlatulentPhreddy's Avatar
PhlatulentPhreddy PhlatulentPhreddy is offline
Re: Brake problem?
I just had my rear drums replaced. They were irreparable and had started making a knocking sound when I stopped. The brake pads at 73,000 on the back are still okay. The drums were shot though and I bought new ones and put them on. I changed the front pads about 30,000 miles ago but even then the Stealer told me I could have gotten more out of them and they are the Hyundai ones with the squeeling thing when they get low. Brakes are much more responsive now. After 5 years you don't realize it as much. Might want to check condition of your drums too. FWIW
Old 06-12-2005, 08:55 PM
v6stang108 v6stang108 is offline
Re: Re: Brake problem?
Do you happen to have a link on how to take the drum brakes off? I have changed the drums from the spindle out (spindle, bearings, cylinder, springs, pads, and new drums) on my old '83 VW Quantum, so this shouldn't be too hard. Thanks
Old 06-13-2005, 10:20 AM
Re: Re: Re: Brake problem?
You can get this info on Hyundai WebTech at their Hyundaiusa.com website. Go to the Owner's forum and click on the Web Tech link for Owners and drill for oil. It will have the schematic you are looking for with parts identified and with corresponding part numbers.
