| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
intake for n/t spyder
I know its not worth modding a n/t but I got a cuople hundreds extra. And ive been wanted a intake, its a 1997 GS spyder. Its seems no1 makes a intake for it. Ive search injen, AEM....google. Does anyone know where I can find a intake system for it? ty for you're time
![]() 97spyderGS |
Re: intake for n/t spyder
A regular ram air intake for a n/t eclipse will work, just flip it the other way. You'll need to buy a coupler to work with the MAS.
So this should work fine right ?
http://www.ajusa.com/cgi-bin/injen/d...c240aa569548b7
![]() 97spyderGS |
cheap ebay intake. it's just pipe and silicone connectors. you could also make the DSM standby "home depot intake".
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
I know I know, I just wanna make sure im gettin the right thing. I would hate to wait a cuople weeks and it be the wrong thing
![]() 97spyderGS |
Re: Re: intake for n/t spyder
-1997 Eclipse Spyder GST |Stock| -1990 Eclipse GSX |ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar| |
So both this http://cgi.ebay.com/ebaymotors/ws/eB...category=38634 and this http://www.ajusa.com/cgi-bin/injen/d...c240aa569548b7 So both these would be fine right? same thing just like 50$ differnce
![]() 97spyderGS |
Jroc an intake for a N/T Eclipse WILL NOT FIT YOUR SPYDER. And I repeat. WILL NOT FIT. 2gnt's do not have a MAS. The spyders do. And no one makes an intake specifically for a spyder. An adapter kit for a 2g turbo eclipse is the only thing that will fit your car. Something like a K&N FIPK.
1999 Eclipse Spyder GST-Race -DSM Link,Injen Intake,Spearco FMIC,HKS SSQ B.O.V.,Apex TurboTimer,Greddy Evo Exh 3",660 injectors,Walbro 255 fuel pump,B&M Fuel Pressure Reg,Heads Ported & Polished,Momo Short Shifter Clutch Masters lightened Flywheel,C.M.Kevlar Clutch,Quaife LSD,Autometer Boost & A/F Gauge, EvoIII B16g Turbo,HKS 272/272 cams & HKS Cam Gears,Crower Valve Springs & Rods,Power Pulley Kit,100 shot Zex Nitrous |
Hey moron... It will work you just have to get a coupler to attach the MAS to the intake pipe. How do you thing people with turbo eclipses make their own intake to turbo set-up?
Jroc - You need that intake pipe plus a 4" to 2-1/2" coupler. Now if you want to get rid of the stock air box you need to get a filter adapter ($5-10 on ebay). That is if you are trying to keep this cheap, if not by all means go buy the most expensive parts but they all work the same. ![]() The second link you listed will only work if you put the MAS in between the pipes so that the harness still reaches. Same materials needed as above but instead of putting the filter on the end of the MAS you put the lower intake pipe which the filter will go on the end of that. The reason this works is you are not a turbocharged car, there for you can put the MAS right next to the throttle body and it will still preform fine! A lot of people dont realize this and they dont want to buy $300 intake setups so you get everything you need when you can go to Home Depot and pick up some couplers for $15. Your decision! |
thnx alot man.....You're alot fo help. Im a new at all this and really just wanted someone to break it down for me and you did. probaly ordering the injen pipe, filter adapter , and coupler(http://cgi.ebay.com/ebaymotors/ws/eB...category=38634) tommorow sometime.
high five lol and this is the only adapter I could of found http://cgi.ebay.com/ebaymotors/ws/eB...category=33659 will the actually apdater work on the injen filter. One again ty for your time
![]() 97spyderGS |
The coupler wont work, it needs to be 4" on one side then narrow down to 2.5" on the other side so the MAS can attach to the intake pipe. Personally I would go with the ram air intake just because it will be easier to work with. Also that filter kit will work fine, only if you get the ram air pipe. Hope that helps.
yeah it does help alot thnx, and and i am gettin the short ram, so the ram and the adapter are set, i just need to find a cuople thnx alot man
I guess the 4' to 2.5 coupler isnt such a big hit cause I cant find it anywhere. Will it be at a pep boys or discount auto parts
![]() 97spyderGS |
Should be... Either that or try Home Depot or Lowes, some plumbing store should have it.
