Old 01-17-2005, 04:41 PM
Cherokeenation Cherokeenation is offline
Cherokee Tranny
What can you guys share about the Auto tranny with OD on the 2000 Cherokees. I want to buy, but have heard that the tranny's may have problems. Also, how do you think these Jeeps rate overall for work vehicles?
Old 01-18-2005, 01:52 AM
IdahoJeeper's Avatar
IdahoJeeper IdahoJeeper is offline
Re: Cherokee Tranny
I have a '96 auto-tranny with OD, never had a lick of trouble. I keep the oil changed and it runs great. I've got 130K on it.
As for work vehicle, I suppose it depends on what you plan to do with it. The guy who had mine before I bought it was a painter, he kept all of his junk in the back and pulled a trailer. Near as I can tell, the only problem was sagging rear springs which can be replaced with Old Man Emu medium or heavy duty springs or I just installed air shocks in the back of mine. This last weekend, I had my XJ STUFFED with boy scouts and gear, with just 35psi in the shocks it didn't sag and rode great...
You like jazz, she likes Klingon opera, so you compromise - you listen to Klingon opera...
You like Cherokees, she likes Grand Cherokees, so you compromise - you buy a Grand Cherokee...
Old 01-18-2005, 06:47 AM
JUSTJEEPS JUSTJEEPS is offline
Re: Cherokee Tranny
Cherokees are very reliable,the trans by far is the best in the Jeep lineup,considering they are a Toyota desighn.
AT JUSTJEEPS WE REPAIR JEEPS FOR A LIVING,NOT FOR FUN.
Old 01-18-2005, 06:48 AM
gtmud gtmud is offline
Re: Cherokee Tranny
I have a 00' Xj with over 97K and never had a problem. I have kept up on the mainentance with fluid changes, running Valvoline fluid. If you are going to use your XJ as a work vehicle I would strongly suggest putting on a cooler. Fairly easy to do and there is just enough room behind the grill to install it. I would say and aftermarket cooler with at least 3/8 tubes.
My Xj has been everywhere, beaches of NC to Oklahoma city. Only thing I have noticed is on long climbs through the mountians of NY if felt a little "soft" , but its been a great vehicle. These vehicles will last a long time IF you keep up on the mainentance, and don't go-cheap when getting things like oil, tranny fluid. After I bought mine I went through and drained everything! Filled the diffs with synthetic gear oil, running Castrol Synblend in the engine, and Valvoline Mercron/Dextron III inthe tranny. Oh and Mobile one Synthetic in the T-case.
Old 01-19-2005, 12:13 PM
Re: Re: Cherokee Tranny
Thanks Guys! I found a XJ2000 at a dealer near here. Has 46,000. The only down side is that it has the command track TC instead of the select-track. Any thoughts on how this effects the function of the vehicle?
Old 01-19-2005, 12:17 PM
mx52nv's Avatar
mx52nv mx52nv is offline
Re: Cherokee Tranny
I didn't think they used command-trac in 2000
current rides:
1990 Turbo Miata
lifted and locked 96 Grand Cherokee with other toys under the hood
retired rides:
1996 Eclipse GSX
1991 Stealth
1991 Porsche 993 C2
1988 BMW 520i
Your SUV isn't a Jeep, and my Jeep isn't an SUV....
SCCA, where you actually learn to drive
Old 01-19-2005, 12:26 PM
"DAIMLERCHRYSLER JEEP CHEROKEE
The vehicle comes with a choice of two or four doors. The new 2001 model also offers a choice of two different types of four-wheel-drive systems: the part-time Command-Trac and the full-time Selec-Trac 4WD systems."
Your right! Should I concentrate on looking for an 01 to make sure I get the select trac. Can a select trac be bolted to an 00 model?
Old 01-19-2005, 12:28 PM
mx52nv's Avatar
Re: Cherokee Tranny
just look for a 96-2001 with the selec-trac and call it a day
current rides:
1990 Turbo Miata
retired rides:
1996 Eclipse GSX
1991 Stealth
1991 Porsche 993 C2
1988 BMW 520i
