Old 01-17-2005, 03:13 PM
bladerogers bladerogers is offline
Block Heater Cord
Does Anybody Know How To Change A Block Heater Cord In A 2000 Caravan? Tips? Thanks
bladerogers
Old 01-18-2005, 03:34 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Block Heater Cord
if your heater core is blocked, try having your cooling system flushed out. If that still doesn't work and you want to manually flush it yourself, that's a tedious task, because you have to pull out the entire dashboard just to gain access to the heater core.
Old 01-18-2005, 03:29 PM
HiRez_L HiRez_L is offline
You can't flush the core from the firewall side on the 2000?
Old 01-18-2005, 10:53 PM
Re: Re: Block Heater Cord
Yes you can, disconnect both heater hoses and flush it out. You can backflush and flush it out the normal way following the direction of flow. That saves anyone from pulling out the dash.
Old 01-18-2005, 11:52 PM
That's the way I've always done it. When you said "If that still doesn't work and you want to manually flush it yourself, that's a tedious task, because you have to pull out the entire dashboard just to gain access to the heater core.", it made it sound as though that wasn't a viable option on the 2000's.
