Old 01-17-2005, 02:13 PM
dagste dagste is offline
Question Flooding 96 caravan 3.0 L
My 96 Caravan 3.0L is flooding with gas!! I pulled the plugs and dried them the van starts and runs well, turn it off and let it sit the plugs are wet with gas again and wont start???
Someone out there must have an idea!!
Old 01-17-2005, 08:36 PM
vipergg vipergg is offline
Re: Flooding 96 caravan 3.0 L
One or more of your fuel injectors are leaking when you shut off the car . This could be from extremely dirty injectors in which a couple of tanks of good fuel system cleaner might help or they may be so bad that only a professional cleaning may help, or you could have bad injectors . Are all the plugs wet or just a couple ?
Old 01-17-2005, 10:40 PM
Re: Re: Flooding 96 caravan 3.0 L
All the plugs are wet!!
Old 01-18-2005, 03:08 PM
hexed775's Avatar
hexed775 hexed775 is offline
sounds just like a problenm I had w/ my s10 pu. Thewre would be so much gas that if gushed out fron the throttle body. we lost 1/4 tank of fuel trying to figure out what was wrong. it was only flooding the 1st & 4th injector. by accident found out the fix.
we soaked the the 1st fuel inj in carb cleaner overnight, when we came back we found that we forgot to remove the upper o-ring. I say upper b/c there is also a lower (we did not know this at the time b/c the lower orings were not on the injectors 1&4, they got chewed up somewhere) until we referenced haynes. check your manual. the lower ones, or lack of, were causing the flooding.
-Nuttin But Problems-
'96 S10 P/U:2.2L MFI:5sp:4x2:LB:Rhino Lining:99k mi
-also-
'02 Dodge Grand Caravan Sport:3.3l:FWD:Stock 51k mi.
