still looking for the answer
I have a 1995 3.1L (3100) when cold the engine hesitates under light throttle if you get into it you can clear is out. As is starts to warm up it goes away usually only happens once during warm up. If you let it sit and cool back down sometimes it does will do it again. Gave it plugs, wires, tps , fuel filter, t-stat. There are no codes present , and uses no antifreeze, but the temp gauge does fluctuate some. Goes up when you slow down and drops when you speed up only has a 7 - 10 degree change when I watched it on the scanner.
Re: still looking for the answer
Sounds like the old choke.
Where do you live that you use no antifreeze?
![]() ClubGP Member 6530 Since 2001 |
