Old 01-17-2005, 11:43 AM
bkrober bkrober is offline
windstar door wont lock
i have a 95 windstar slideing door wont lock at all with or without key can any tell me what to check
Old 01-18-2005, 06:09 PM
Dngrsone's Avatar
Dngrsone Dngrsone is offline
Send a message via ICQ to Dngrsone Send a message via Yahoo to Dngrsone
Re: windstar door wont lock
There are four contacts on the door at the front... use a red eraser or very fine emory cloth to polish the crud off of the contacts both on the frame and the door. If you have some dielectric grease or TV tuner cleaner, treat the cleaned contacts with one of those... that will likely solve your problem.
2003 Ford Expedition 4.6L (Dngrswife's)
2006 Kia Sedona
2008 Toyota Prius (totaled)
1997 Windstar 3.8 liter (retired)
Replaced Head Gaskets
1988 S-10 2.8 liter (retired)
Full Rebuild
Old 01-18-2005, 10:28 PM
Re: Re: windstar door wont lock
I tryed the earser that didnt work so i'll try the others thanks
Old 01-19-2005, 02:15 PM
12Ounce 12Ounce is offline
If you are saying the door can't be locked even using the inside locking plunger knob.... then I would guess a linkage has "come undone" inside the door trim panel.
Old 01-19-2005, 09:08 PM
yotermanic yotermanic is offline
Does the door lock and unlock when the door is open? This would point to a door alignment problem. Does it lock and unlock with the knob? The knob uses a different linkage than the cylinder. If it won't lock or unlock from the knob, cylinder, or power locks, then it points to a door latch sticking. You could try spraying brake clean on it since it will remove dirt build up but not leave a residue to attract more dirt but if it is a latch, you'll probably need to get it replaced. Good luck with it.
