Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-17-2005, 09:20 AM
ice745 ice745 is offline
AF -Advisor
Best oil filter for '94 4 cyls.
When I got my car I was a little interested in the fact that the oil filter was at the top of the engin and upside down from normal positions. This made it impossible to partially fill the filter before putting it on. One thing I would do is fill it up, let the filter soak the oil, then empty it out into the funnel in the crankcase. Then at least the filter element was already wet. However shopping at Advance I saw the "Fram Tough Guard" filters, they have a drainback stop valve, so when the oil goes in it can't come back out with out the pressure of a running engine. This is great for the car in two aspects. First, when you do an oil change if you do what I said above, only a few drops will go out into the funnel, the rest is retained. Secondly when the car is parked, oil is still in the filter which makes for better starts. They are also rated for 99% multi-pass efficiency. I don't know if the regular orange Fram filters also have the anti-drainback valve. I use the tough guard and Pennzoil stop and go oil, because I drive a lot of stop and go short distances. Hopefully this summer after school I will get some nice highway mileage. Any other opinions just post them up.
Smoking is bad... especially blue smoke!
Fill the oil and check the gas, please.
Old 01-17-2005, 08:43 PM
dschwartz46 dschwartz46 is offline
You can't beat K&N fillters...
http://knfilters.com/oilfilter.htm
Old 01-17-2005, 09:45 PM
AF -Advisor
Re: Best oil filter for '94 4 cyls.
...You can when it comes to price. I can't justify paying 10 dollars for an oil filter which isn't going to greatly affect the performance of my engine. Maybe if I could only change it half as often, then the doubled price would be justifyable. Is it safe to do this with K&N?
Old 01-17-2005, 10:49 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
After all the bad reports I've heard about Fram oil filters, you couldn't give me one.
Here's a serious alternative:
http://www.autoenginelube.com/pages/903473/index.htm
Old 01-18-2005, 06:10 PM
Blitzgray Blitzgray is offline
I am pretty sure that a Toyota filter has a backflow valve in it.
Old 03-11-2005, 02:53 PM
toeppe85 toeppe85 is offline
hello,
just to get the record straight, FRAM makes a very good oil filter. now i not only say that because i am an engineer for honeywell, but because we test them against many other brands to compare results. almost always, fram beats the competitition. it meets or beats the oem filter also. there are a lot of reports saying how bad fram is, but in all reality, its probably one of the best filters on the market, with a very reasonable price
Old 03-11-2005, 04:55 PM
rum runner rum runner is offline
Fram “tough guard” not “double guard” are good filters although they have a card-board end inside. If you are picky, use Toyota filters and Mobil one synthetic oil. K&N, Wix, Purlator, AC Delco, Fram tough guard all good filters.
With synthetic oil it really doesn’t matter what filter you use, the motor will last 300,000 if changed every 6,000 miles
Old 03-12-2005, 05:16 AM
Bossman Bossman is offline
You don't really need to "fill" the oil filter up all the way before installing it. Just add enough oil to wet the fibers inside and then install it.
Old 03-28-2005, 01:54 AM
yoji6365 yoji6365 is offline
Where did you get this technique. I've never heard of it, never seen anyone do it, never saw it in a textbook, nothing, nada.
Anyone that changes the oil at 3k shouldnt care what filter they use.
Then again, anyone that changes oil at 3k isnt worried about spending the money.
Old 03-28-2005, 12:10 PM
Brian R.'s Avatar
Resident Chemist
Re: Re: Best oil filter for '94 4 cyls.
Even if he didn't read about it somewhere, it can't hurt anything. At best, it helps whet the filter element with the oil he's using and may make it easier for oil to penetrate the filter element. It is basically identical to what ice745 used to do.
I guess they are both using their brains without having to have read about it somewhere.
Interesting point of view. What are your recommendations for oil-change intervals and filter brands?
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 04-06-2005, 08:42 PM
Brian R.'s Avatar
Resident Chemist
A discussion of Frams:
http://theoildrop.server101.com/ubb/...c;f=6;t=002355
Old 04-11-2005, 03:03 PM
quincyguy quincyguy is offline
As long as they're not 1.99/ea @ the drug store, I'll buy 'em.
Don't care what name's om 'em
'90 Camry turning 200k very soon
Old 04-16-2005, 06:16 AM
Re: Re: Re: Best oil filter for '94 4 cyls.
I guess they are both using their brains without having to have read it somewhere.
Thank you, Brian.....I'm no mechanic but I'll take this as a compliment! Have a nice weekend.
Old 04-16-2005, 01:56 PM
Brian R.'s Avatar
Resident Chemist
I feel obliged to defend people who think like I do...
