Old 01-17-2005, 07:10 AM
elmuertenegro elmuertenegro is offline
New Purchase
I am thinking about buying a VR4 or a TT Stealth. Most of the ones that I find are sitting around 100k to 150k miles on them. What should I expect to go wrong with them in the near future? What kind of things should I be looking for? Also, and I know this is a subjective question, why should I choose one over the other?
Thanks in advance,
Chris
Old 01-17-2005, 08:14 AM
Boosted1 Boosted1 is offline
I got my VR4 with 138k miles on it. So far, the following things have gone wrong with it:
Water pump
Timing belt
Thermostat
Transmission (2nd gear sychro)
Those were the major things anyway. It now has about 155k on it. They are not easy cars to maintain sometimes. But very fun.
1993 Mitsubishi 3000GT VR4 (STOCK)
1989 5.0L Ford Mustang (MODIFIED)
http://www.cardomain.com/memberpage/761789
Old 01-17-2005, 02:30 PM
sLADe781 sLADe781 is offline
Re: New Purchase
Boosted1, how much did it cost you when you repaired your 2nd gear synchro? Mine probably needs repairing too....
Old 01-17-2005, 02:42 PM
Jag1718 Jag1718 is offline
While both cars are great cars. It's a matter of your own opinion. That's the best advice I can give you. I tend to say the 3kgt over the stealth because, well, IMO the 3kgt is the nicer car, exterior wise. Some may disagree but that's their opinion. Choose the one with ur kind of styling. Both look very similar so u can't go wrong with either. I think a stealth TT would be cheaper to had than a 3kgt TT.
Old 01-17-2005, 03:35 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: New Purchase
slade it ran me 600
Old 01-17-2005, 05:40 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: New Purchase
Water pump
Timing belt
Thermostat
Did the belt and pump fail or did you just need to replace them?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 01-17-2005, 06:15 PM
The1NamedMarc's Avatar
The1NamedMarc The1NamedMarc is offline
Send a message via AIM to The1NamedMarc
Re: New Purchase
This is just me but I personally would only get a 95+ VR4 or 94-96 RT/TT. I see a lot more problems with 91-93 3k's but there are also more of those made.
Depending on how the car was treated, you could run into lots of problems. I've had mine over a year and had 1 problem. My intake manifold pressure sensor took a shit on me. It's not a big deal though. I've been running the car with the CEL on for 6 months now. I can use my datalogger and clear it whenever though.
100K+ miles is a lot but it all comes down on how the car was treated. If you are going to buy one of these cars, you MUST have money that you are willing to spend in order to fix the car. You are fooling yourself if you think you will have no problems.
Old 01-18-2005, 01:32 PM
2old 2old is offline
Re: Re: New Purchase
You usually replace them because you can't afford to fix the engine if they fail... I had a dealer replace a belt and pump and they screwed up the belt tensioner and the timing belt broke on the highway.
Luckly it was covered by the dealership b/c they screwed up but it cost them $9000 (Cdn) to re-build the engine. (Although I wished it did more damage b/c if it was any more expensive they would have just bought a new engine)
Old 01-18-2005, 05:42 PM
Originally Posted by youngvr4
slade it ran me 600
Awe crap.... Did you fix only your 2nd synchro or your 3rd as well?
