Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 01-17-2005, 06:37 AM
skeeze skeeze is offline
Short killing battery
1992 Olds 98 Regency. The car has a short that will kill the battery over night. I hooked a test light between neg battery post and cable. When #11 fuse is pulled the test light goes out. #11 fuse is radio, oil age, oil level and dash lights. Has anyone had this problem? I would appreciate any and all help. Thanks
Old 01-23-2005, 10:13 PM
back2life's Avatar
back2life back2life is offline
Re: Short killing battery
Make Sure Radio Is Not Staying On If It Is You Have A Backwards Memory And Power Wire On The Radio If Its After Market Or Been Replaced. Also Have The Battery Checked
Old 02-04-2005, 09:50 PM
chuck1985 chuck1985 is offline
I had a problem with my power antenna shorting out. It would drain the battery overnight on many occasions.
Old 02-08-2005, 12:15 PM
back2life's Avatar
im not familiar with a short causing battery drain? is the antenna motor continously running? if it is unplug it behind the trunk cover on the right side. if not have your battery and alternator tested
Old 02-09-2005, 09:36 PM
Hansnet's Avatar
Hansnet Hansnet is offline
ELC Struts are leaking causing motor to stay on.
or bad power antenna
or bad battery.
Everytime the battery runs down it looses 10% of its capacity.
Old 08-24-2005, 07:22 PM
daytonadon8 daytonadon8 is offline
Having the same problem in 91 Olds 98 Regency Elite....If I take out N. 11 fuse ....radio...lighter...dash lights.....power antenna...chime..the problem is eliminated......if i disconnect neg. battery cable then touch the battery you can hear chime.....any quick Fix ????
