Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-17-2005, 04:01 AM
elwaydavis elwaydavis is offline
Stalling when clutch pushed in
The problem that I'm having is with my 95 Eagle Talon; when I'm driving and push in the clutch, the RPM's will either drop below idle speed and then jump back up to the normal idle position, or they will fall to zero and the car will basically stall with the clutch still in. The car seems stall more often when the air conditioner is on. Do you have any idea what the problem could be? (regular maintance just performed: timing belt, valve cover gasket replaced, new spark plugs and spark plug wires)
Thanks for any info,
-Jon, 95 non-turbo eagle talon 5 speed manual
Old 01-21-2005, 09:50 AM
talonlover's Avatar
talonlover talonlover is offline
Re: Stalling when clutch pushed in
I hope it's not crankwalk...
Old 01-21-2005, 03:48 PM
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
Re: Re: Stalling when clutch pushed in
Stop crying crank walk!!!!!!!!!!!!!!!!!!!!!!!!! OMG its people like you that give the 2g elclipse a bad name!! i swear to god i know like 5 people that give the 2g NO repsect because of crank walk fears. I bet you any amount of money that he doesn't have crank walk!
i had that problem on my turbo, it was a boost leak, plugs and wires and the idle regulator setting.
since you don't have boost, and have new wires, check the idle speed regulator thingy. basily the cars not idling high enough to run. does it happened differently in colder weather? mine was only bad when it was cold. i'd reconmend taking it to a dealer and checking it out, might be that setting or could need a tune up and check the timing... also check fuel filter and air filter. when i cleaned my air filter it fixed half the problem
Something new is coming...
Old 01-21-2005, 09:49 PM
talonlover's Avatar
If you don't like the answer then don't ask the question. A: I DID NOT diagnose the problem, I simply stated it as an possible answer
B: this was taken from a tsb:
How can I tell if I have crankwalk?
Its not easy to diagnose whether or not your car has crankwalk. It can be difficult to tell if a particular car is experiencing symptoms of crankwalk. Some early warning symptoms associated with this problem are :
1. Clutch weirdness, improper pedal pressure, strange disengage and engage points
2. Ticking or strange noise from the pulley side of the engine when clutch is depressed.
3. Crank Angle Sensor errors ( check engine light )
4. Difficulty shifting
5. RPMS decreasing significantly when clutch pedal is depressed.
6. Clutch does not return or "sticks" to the floor after being depressed
PS< I missed the sig of his car being NA. That's my fault, but the problem has happened to non turbo 4g63 engines, just not as common.
1981 Delorean DMC-12 frame off resto. 2006
Old 01-22-2005, 05:49 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
his is a 95 NT which means he has a 420a motor. crankwalk is very rare on 4g63's and even rarer on other motors.
i would recommend cleaning your TB and idle speed control motor.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 01-22-2005, 07:41 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Do you have a check engine light?
For Sale 98 Eclipse GS, 5 spd
Old 01-22-2005, 09:03 PM
talonlover's Avatar
I thought you could get the 4g63 in a nonturbo version as well?
Heres a little somthin for you to read up on:
Specification Base model Mid model Upper model (FWD) Upper model (AWD)
Eclipse model names RS GS GS-T GSX
Talon model names - ESi TSi TSi AWD
Engine type 2.0L 2.0L 2.0L turbo 2.0L turbo
Old 01-22-2005, 09:13 PM
talonlover's Avatar
I'm done with this thread, he probably isn't even reading it anyway. Jezzz, the mere mention of CW put all of you in a tiz and I didn't even say that was the problem! I sincerely hope it is not, and I doubt it is anyway. After thinking about it has anyone on this problem mentioned the BISS screw(I don't know if the 2g has them but Im pretty sure they do.
Old 01-23-2005, 07:19 AM
ashah000's Avatar
2gNT's came with the 420a!
Old 01-23-2005, 09:04 AM
talonlover's Avatar
wasn't debating that, you get 3 diff. engines...420a, 4g63, 4g63t
Old 01-23-2005, 02:16 PM
2G's DONT come with a NT 4g63. Just the 420a NT or the 4g63 turbo.
BTW 1G is 90-94. 2G is 95-99. 3G is 2000-2005 and 4G will come out 2006 model year
-1stGenRocks-
Old 01-23-2005, 02:34 PM
I've got the 420a engine and I alsio thought it may have something to do with the idle regulation. (and i am reding all the comments thank you very much) I just want to thank everyone for their ideas; I am going to try some things based on what everyone left and i'll get back to you. WISH ME LUCK.
- Jon, 95 non-turbo eagle talon 5 speed manual
p.s.- no check engine light
Old 01-23-2005, 02:37 PM
talonlover's Avatar
My mistake, where have I seen the 4g63 in a nt format? I could have sworn that I have seen this on 1g cars. Did Mitsubishi ever make this engine in a Eclipse in a na form?
Old 01-23-2005, 02:45 PM
yes they made a NT 4g63 in 1G's and some other mitsu and hyundai cars.
-1stGenRocks-
Old 01-23-2005, 02:48 PM
talonlover's Avatar
Well at least I know I'm not going crazy.
