Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-16-2005, 09:54 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Those w/boostguages....
Just curious... what is your vac at when at a steady cruise...like 55mph and what is it at when your at a stoplight (autos only for this)
Thanks for any comments!!!
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 01-16-2005, 11:41 PM
jdoug jdoug is offline
Send a message via Yahoo to jdoug
About -10 at cruise and about -20 at idle (yes, it's A/T). Remember that altitude also influences the readings-- for reference, I'm pretty much right at sea level.
J Doug
2003 Mustang Mach 1
1998 Mitsubishi Eclipse GS-T *sold*
Old 01-16-2005, 11:44 PM
GotGrip666's Avatar
GotGrip666 GotGrip666 is offline
Banned
Re: Those w/boostguages....
cool i was about to ask what it should be at idle and mine is at -20, the reason i was gonna ask is because every picture i see of boost guages they are allways on 0
Old 01-17-2005, 12:31 AM
joemathews's Avatar
joemathews joemathews is offline
I used to be right at 20 in. hg with my T25, but now I'm around 13-15 with my Evo 16g.
Probably just Jake having broken my car..
At cruising speeds it is entirely relative to throttle position.
1996 Eagle Talon
Old 01-18-2005, 01:11 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: Re: Those w/boostguages....
Did you put cams in? Sounds like timing is off.
Kris
2012 Genesis Coupe 2.0t
Old 01-18-2005, 03:07 PM
joemathews's Avatar
Well, I have an exhaust leak somewhere that I have yet to pinpoint. It's either turbo to manifold or turbo to o2 housing I think. So I suppose that may be causing it...what do you think?
I believe timing is good, the car runs smoothly and I trust Jake's timing work. I'll have to take it to a shop up here and see if they can fix the exhaust leak--I don't have anywhere to work on the car up here, and there's no way in hell I am working on it in the parking lot in 15 degree weather
1996 Eagle Talon
Old 01-18-2005, 03:11 PM
Dunno. That is way off for no cams and 5*BTDC, but I suppose a BIG leak could do it.
Kris
Old 01-18-2005, 03:20 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Does less vacuum mean anything in terms of idling well, which is the intermediate effect of cams? Not sure if that makes sense. Is less or more vacuum bad for the engine?
Old 01-18-2005, 03:32 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Its not at 13! When I was there it was at 17. Same place mine is at right now. I have never had a car run 20, even stock. Now with timing, there is no way to adjust 95-96 cause they dont use and adjustable cam/crank sensors. Took it off and put it back on just like any other car I have done.
Old 01-18-2005, 04:44 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
I usually get 15-16 (sometimes 17) inches of Hg at idle - stock cams/head/intake mani/no vacuum/boost leaks or very very minute leaks if any. It seems to vary slightly with the weather, but I'm not sure whether or not it really is the weather that is effecting my vacuum.
I've always been told that 18-20 inches was what it should be at idle for our cars with stock cams. However, I've never been able to achieve that for some reason. I'm also about 650 feet above sea level, if that means anything.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 01-18-2005, 04:52 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
During the weekend im gonna see what mine reads at....i hope its where its supposed to be too...
99 GST/evo 3 16g/3" Catback/Intake w/filter/UICP/1g BOV/Complete prothane motor mount inserts/Boost gauge/AF ratio gauge/MBC/NGK Plugs/HotWires/17" Sport edition fox 5 racing rims w/Fuzion tires
One retarded ass site! Geeeeeeeee
My Car
[url=http://www.myspace.com/nobledsm[/URL]
Old 01-18-2005, 10:19 PM
thanks for the info!!! When i'm at cruise of 55mph my vac is about 10Hg and when at a stop light idle is about 600 and vac is 18-20hg
Also when my foot slips of the brake and 'accidentally' hits the gas it goes to about 13-14psi....hmmmm whatever that is.... te he he
Nah anyways just thought i'd see what the masses had to say... Thanks
