no start
in the last few months we have had trouble starting . Turn key but no ignition . we would try pushing the key in harder and holding as it was turned and would get ignition . then it quit altogther . I can hear the fuel pump coming on and that is it . I pulled the starter had it tested and it passed with flying colors although it was sounding a little worn , so i put in a new starter , still no ignition,NO SOLENOID CLICK OR STARTER TURN . I replaced the ignition switch and the clutch switch ...still nothing . then my key cylinder froze up...so I drilled that out and put in a new one at a cost of $85 , its the third one I might add ! That cylinder works better now than when I paid ford to do the other one. I HAVE GONE OVER THIS THING WITH A CIRCUIT TESTER AND ALL THE CIRCUITS I CAN FIND TEST FINE . Including testing all fuses in the engine and passenger compartments as well as the plug ins on the wiring harness AND SWITCHES (UPPER AND LOWER CLUTCH SWITCHES ) . I have power to my starting solenoid and a solid unbroken ground .I HAVE TESTED THE RELAYS AND THEY ARE FINE .
i HAVE A QUESTION : ARE THERE ANY ELECTRICAL CONTACTS IN THE STEERING COLUMN , WHEN I HAD THE KEY CYLINDER OUT , I PULLED OUT THE PLUNGER AND SPRING AND THE PIN AND SPRING AND LOOKED AROUND WITH A PEN LIGHT AND THOUGHT I SAW SOME SORT OF CONTACT, OTHERWISE WHERE ELSE CAN MY PROBLEM BE ..IGNITION COIL ? PCM? DIODE ...AND WHERE WOULD I FIND THE DIODE ? |
Sounds like the last thing to look at is the ignition coil. Otherwise i'd say you're pretty much screwed... what year is your Focus and how many miles/kilometers are on the thing???
Mine's an '82 Pontiac Parisienne 4-door sedan!! - 305 cu inch (5.0L) small block V8 w/ 3spd auto - 4 barrel carb w/ single exhaust - No catalytic converter, no posi-trac NEVER LOSE FAITH IN THE BOAT!! |
Re: no start
Tonailer Sup Man,did You Ever Fugure Out What The Problem Was On The 2000 Focus With No Start,im Having The Same Problem And Was Hoping You Might Could Shed Some Light On The Subject,cause The One Im Working On Is Doing The Exact Same Thing,i Havent Checked The Ignition Yet Though,take Care Buddy Hope You Got It Fixed,don,r
