Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 01-16-2005, 09:37 PM
88fingers 88fingers is offline
head gasket replacement
We took the car out of the driveway here the other day and the temperature started to skyrocket (outside temp. was around -25 C). I pulled over and let the car idle and the temp went back down. The guys at the garage told me that the coolant fan was not working due to a computer problem. He also told me that the head had warped and would need remachining. They want $1400 to do the work! Has anyone had similar problems with their saturns or heard of the technical bullitens outlining this a typical saturn problem?
Thanks,
Old 01-16-2005, 10:35 PM
carguy83 carguy83 is offline
Send a message via AIM to carguy83
Re: head gasket replacement
new
engine
not worth the repair
1995 Gold Saturn SL2 -- RIP May 05
1991 Blue Subaru Legacy Wagon -- RIP Aug 05
1995 White Mazda 626 DX -- RIP Feb 07
1991 Black Volkswagen Jetta Carat -- Current
Old 01-16-2005, 11:32 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
overheating may cause a head to warp, but you can't really tell without removing the head. if he is assuming the head is warped because the gauge said it overheated once, i would run away, fast. if the engine is runing perfictly normal, then out of sight out of mind.
however, i bet your ECT sensor needs replaced, you can do it yourself for less then $20. - http://www.saturnfans.com/forums/showthread.php?t=24003
