Old 01-16-2005, 09:08 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Cleaning decals?
what do you guys use to clean off decals before applying clear coat? I was going to use wax but i figure the clear wont stick to it. Also how long after a decal (cf) is applied, can you clear it? Thanks
In Progress
Old 01-16-2005, 09:15 PM
freakray freakray is offline
AF Modelrater
Re: Cleaning decals?
Wax would prevent the clear from sticking to the surface.
Wait at least a week before clearing over any sort of decals.
AF User Guidelines
Old 01-16-2005, 09:28 PM
RallyRaider's Avatar
Zomby Woof
How do you mean clean the decals - are they dirty, or do you just mean excess glue residue? If the latter, a very gentle wash under running water does the trick.
As for how long to wait before clear coating, I guess the simple answer is until it's dry. How long that actually takes can vary, depending on a number of factors. As Ray says a week to be safe, but you could probably get away with just a couple of days if the weather is good.
Old 01-16-2005, 09:29 PM
MidMazar's Avatar
it seems like there is a smudge on it, don't want to clear it before i get rid of it, or itll look ugly.
In Progress
Old 01-16-2005, 09:33 PM
AF Modelrater
Then I would recommend as Phil mentioned, just gently clean if under running water, or even use a soft damp cloth, just be careful not to damage the decals.
AF User Guidelines
Old 01-16-2005, 09:34 PM
Zomby Woof
In that case can you could try some polishing compound to remove it. Very gently!
Old 01-16-2005, 10:04 PM
MidMazar's Avatar
thanks guys, phil i'll use some compound.
In Progress
