Old 01-16-2005, 09:07 PM
stretch-armstrong stretch-armstrong is offline
kit decals and clear coat?
Is it safe to put on the decals from a kit and then clear coat over them?
Old 01-16-2005, 09:10 PM
Vric's Avatar
Vric Vric is offline
Re: kit decals and clear coat?
This question is the most popular here.
There is no clear yes or no, so Try the search
Old 01-16-2005, 09:17 PM
freakray freakray is offline
AF Modelrater
Eric is quite right, and in all honesty there is no perfect answer, since the subject has come up in the last week the search function will most definitely answer your question.
AF User Guidelines
Old 01-18-2005, 10:44 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
I'd say it depends more on the clear than the decal... Acrylics, enamels and urethanes seem to be the safest, lacquers the most likely to make a meal of the decals. You just have to test first if you're in doubt... - Mark
Old 01-18-2005, 12:02 PM
Laaars Laaars is offline
But when this question is here;
How is it to apply decals to a car with clear coat? Will they fall off? Or do they sit very well?
Old 01-18-2005, 01:28 PM
spidereddie's Avatar
spidereddie spidereddie is offline
Send a message via AIM to spidereddie Send a message via Yahoo to spidereddie
wow guys. deja vu.
Apparently this whole 'search' thing is pretty difficult. So here goes...
A "how-to" for searching.
The search button is the little gray sqaure at the top right corner of the thread list. it has the letters G. and O. on it. There is a field for you to type in the keywords to the left of that button. You should see the words "search this forum". Type and click and read away!
sorry I have no pics. hehehe
Ed-
Old 01-18-2005, 01:30 PM
CADguy's Avatar
CADguy CADguy is offline
Re: Re: kit decals and clear coat?
They should sit fine over paint with a clearcoat. If you have waxed the model, that is a different story..
Matt
Old 01-18-2005, 02:49 PM
Sticky Fingers's Avatar
Sticky Fingers Sticky Fingers is offline
I'm a newbie so take my words with a pinch of salt!
The only model I've built so far had acrylics and enamel paint on the body. I clear coated the whole car then put microsol on the area(s) I wanted to put the decals on and it all worked out fine. The sheen of the gloss coupled with the microsol made decal maneouvering on the body a relatively painless task. However, take care with the microsol because I put too much on the back bumper and ended up with a decal which folded in on itself!! The decal had to go in the bin and the other decals on the back had to be rearranged to make up for the missing decal!!
Hope this helps!
In progress : Peugeot 206 WRC '02 Safari
Old 01-18-2005, 03:04 PM
chacal's Avatar
chacal chacal is offline
Originally Posted by spidereddie
wow guys. deja vu.
Life's hard, than you die. LIVE!
http://www.csicop.org/
Old 01-18-2005, 09:44 PM
scaleracecars scaleracecars is offline
Actually it is about the decals as much as it is the clear coat. Decals are printed with enamel, lacquer, acrylic and UV cured inks. Depending on which inks were used is what make a decal react to a topcoat. You can test your decals by placing some striaght thinnner on an extra part of the decals sheet to see if there is a reaction before spraying your clear coat.
David
http://www.scaleracecars.com
