Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 01-16-2005, 08:41 PM
Steve415 Steve415 is offline
parking brake light stays on, headlights won't work!
My parking brake light stays on, even when the brake is off. Strangely, when the brake light stays on, the headlight, fan and window washers don't work. However, the highbeams and radio will work. (When I drive at night, I have to hold the highbeam light on with the stick.)
Suggestion?
Thanks!
Steve
Old 01-17-2005, 08:53 PM
boschmann boschmann is offline
Re: parking brake light stays on, headlights won't work!
One part sounds like the hand brake switch isn't working, but that wouldn't affect the fan & washers. Just because it's a '98 I'd suspect the ignition switch. Try jiggling/slightly turning the key & see if it changes things.
Old 01-19-2005, 12:05 PM
efxmedia efxmedia is offline
Same problem . . .
Steve,
Have you found a solution? I'm having the exact same problem on my 97 VW Jetta.
boschmann,
I've tried the ignition switch - nothing happens.
Thanks,
Michael
Old 01-19-2005, 03:39 PM
Most strange phenomena like yours was a switch problem. Sometimes moving the switch back & forth helps show it's the culprit, sometimes it doesn't. To prove what is causing it you might have to spend some time with a wiring diagram & multimeter.
Old 01-19-2005, 04:38 PM
Re: Re: parking brake light stays on, headlights won't work!
boschmann
Thanks for getting back with me.
I was afraid you were going to mention a wiring diagram... Once I find one, I'll give it a shot and let you know what happens.
Thanks!
Michael
Old 01-31-2005, 02:54 PM
BluesCruiser BluesCruiser is offline
when I bought my 97 jetta 2.0 in the glovebox was a letter from VW
about a recall on the Switch because of that problem good for 8 years or 100.000 miles I would be glad to fax it to you .
Old 02-01-2005, 02:51 PM
Thumbs up Re: parking brake light stays on, headlights won't work!
BluesCruiser - that would be great! Especially as my VW dealer quoted me a pricetag of $1,000 - $1,200 to fix it (without mention of a recall).
My fax is (xxx)xxx-xxxx.
Thanks,
Michael
michael(at)e-fxmedia.com
