Old 01-16-2005, 07:04 PM
3000-G_T_S_L 3000-G_T_S_L is offline
Send a message via AIM to 3000-G_T_S_L
Pimp my Ride....
I want to lower my 3k to the ground. What is the easiest, safest, and most cost effiecent way of lowering my 3k about 4-6 inches.... tryin to get rid of my nasty wheel gap. Please offer any info or links to products so I can check em out....thanks!!! ^_^
1999 Pearl White 3000GT SL - Sold
1992 Dark Green 3000GT VR4 - Spun Bearing
2006 Black Suzuki Katana 600cc -hit from behind, totaled
*JUST BOUGHT*2008 Red Mitsubishi Lancer ES - planning
Old 01-16-2005, 07:05 PM
oh yea, one more thing....anyone know where I can get a decent horn and install it? The stock horn is kinda squeaky soundin' thanks again
Old 01-16-2005, 08:59 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: Pimp my Ride....
4-6 inches? is this for show? If so an airbag suspension would probably be the best. If not you could go with a coil over setup.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 01-16-2005, 09:02 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
The wheel gap isn't anywhere near 6"... I reccomend looking into intrax since they have the largest drop (1.5-1.75") among the name brands I know of. Please don't go rice.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 01-16-2005, 09:05 PM
Hmm, would lowering it a little bit to reduce wheel gap acutally be considered "going rice"? I just thought it'd look better a little lower, and would prob help with aerodynamics..... I'm open to all thoughts tho, keep em comin, thanks ^_^
Old 01-16-2005, 09:07 PM
Re: Re: Pimp my Ride....
Oh, to answer your question it's not for like any type of contest, just somethin I kinda wanna do. Like tons of other things I wanna do to my car, gotta figure out what I wanna do first when I have the money.
Old 01-16-2005, 09:15 PM
StealthModifier StealthModifier is offline
i wouldnt do more than a 2-1/2 inch drop.. i think u can pull off a 3 inch drop with some coil overs. the wheel gap on these cars is only 3 inches
Old 01-16-2005, 09:41 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Yeah I want that gap gone too...it's huge!
Old 01-16-2005, 09:46 PM
Thourun's Avatar
It was the huge lowering you said you wanted and the horn thing that made me think rice (honestly do you use your horn enough to justify geting a vanity one?). Just don't go past about 3" and it should still look and handle sharply, the areodynamics are not what people do it for but your right in that lowering it will help by creating more downforce due to restricted airflow under the car and the same airflow over the car, you can get a similar effect by geting sideskirts and a front bumper that are 'taller'.
1995 3000GT VR-4
Old 01-16-2005, 09:47 PM
same here, but then i wouldnt have a font bumper
Old 01-16-2005, 09:55 PM
Thourun's Avatar
Aww you could shave off a little! I thought yours was lowered allready though?
1995 3000GT VR-4
Old 01-16-2005, 10:45 PM
Hotshot8792 Hotshot8792 is offline
your best bet are the ground controls from www.3sxperformance.com
bear in mind though, when you lower the rear anymore then 1 inch, it will set your rear camber off and you will wear out your rear tires very quickly. To get around this, you will have to buy and install adjustable control arms that 3sx also sells, or some local board members from 3si might sell as well.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 01-17-2005, 01:31 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Hotshot, is it necessary to get the adjustable control arms? can't you just get the rear tires re-aligned at an alignment shop?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 01-17-2005, 11:05 AM
lol, naw its not lowered any, i was thinkin of puttin a 1.5" drop on it tho
Old 01-17-2005, 01:18 PM
Wow, this is tons of information, and exactly what I was looking for. The 6 inch drop is way too much, I went and looked again, I think 6 was a close random number that I just typed tho.... Thanks to everyone who gave their info, you people are the ones who make this forum so great. I'm thinking only a 1.5 inch drop or so will look good. Putting side skirts on it wouldn't work to rid wheel gap. As far as the rear tires wearing out, is there any way besides those bars to prevent that? An alignment job was mentioned, will that not suffice? I gotta new avatar, took that pic last night with my phone...
