Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 01-16-2005, 05:34 PM
BODYMAN BODYMAN is offline
Will Not Start
Have A 1997 Ford Explorer. Is There A Way To By Pass
Alarm System So It Will Start. Something Has Shut
Down System Preventing It From Starting. Checked
Fuel Shut Down Switch It 's Ok. Don"t Have Remote
For Alarm System.
Need Help
Bodyman
Old 01-16-2005, 05:57 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Will Not Start
For Alarm System.
Need Help
Bodyman
Is this OEM alarm????
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 01-16-2005, 06:26 PM
alarm
it has factory alarm system. i have 5 digit code that came with
explorer. i tryed spraying starting fluid in injector port and it will
not start. that is why i think system has been shut down.
been running great . then this happen.
Old 01-17-2005, 06:04 PM
Re: alarm
Your car should only have an entry alarm and not a fuel or engine shut down. You got something else going on.
Pioneer 4900mp
Orion C63 Coax rear
Old 01-18-2005, 08:48 PM
m_klarich m_klarich is offline
Re: Will Not Start
Hey, I had the same problem last year. Try this.
Crank the motor, if the check engine light flashs then check the connection and wires to the crankshaft rotation sensor. Mine had corroded a little and just required unplugging and plugging back in.
Sensor is located at the front of the motor at the bottom right on the crankshaft pulley. Find the lowest pulley that the belt goes around, find the sensor and check the plug and wire.
Mine fired right up after I worked on it for 3 days.
Matt
Old 01-21-2005, 10:13 AM
2001Sport_Traccer 2001Sport_Traccer is offline
Re: Re: Will Not Start
If it was the factory alarm that is triggered by the Key, the dash light would be activated as it is when you attempt to start a Ford with a 'plain' or duplicated key, as opposed to the $80 one with the transmitter in it.
What you need...is a computer code check, if you know anyone or have the $100 for an OBD II system to plug into it.
Old 01-22-2005, 04:54 PM
Re: Re: Re: Will Not Start
the 97 model year doesn't have that.
Pioneer 4900mp
Orion C63 Coax rear
Old 01-24-2005, 10:55 AM
Re: Will Not Start
Have you tried m_klarich's suggestion yet? (I couldn't if I wanted to just yet; it hasn't risen above 27 degrees F here in Tennessee, heh.)
