Old 01-16-2005, 02:20 PM
Y_Lee_Coyote Y_Lee_Coyote is offline
Hesitation, stalling Please Help!!!
I have a 91 s10 blazer with a 4.3 V6. about two weeks ago coming home from work it started hesitating (bucking) realy bad so I pulled into a rest area were it stalled. It will start back up but you can smell fuel as if it was fluded.
After two weeks I have noticed this pattern: in the morning starts up just fine after about 10 min of driving it starts its hesitating. If I have to come to a stop when Its doing this it will stall. If I can keep accelerating through it it will eventualy stop ( warm Up? ) and run fine the rest of the way to work.
I have changed the plugs, coil, cap, cleaned the TBI with throtle body cleaner.
This is driving me crazy.
Somone please help!!!!
Old 01-16-2005, 03:58 PM
OverBoardProject OverBoardProject is offline
Banned
Re: Hesitation, stalling Please Help!!!
Get the computer read first, but I'd almost think Oxygen sensor.
Old 01-16-2005, 06:25 PM
s10bajadan s10bajadan is offline
I would say, check for codes .
When was the last time the fuel filter was changed?
There's a common problem with bad grounds /connections on fuel pump.(you have to change it to correct it.)
Just a few other things to consider...
Old 01-16-2005, 08:43 PM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
check your egr valve. does your check engine light come on?? if not you wont have any codes stored.
if so to read the code is easy. all you need is a wire about 3 or 4 inches long. for a 91 you dont need a code reader the truck will give you the codes its self with a very simple procedure. let me now about the engine light and if you need to know how ill post a nother reply to let you know how.
i have a 91 s10 blazer myself . similar problem turned out to be carbon build up in the egr valve
keeping it open. easy to take off and clean.
let us know how you are doing.
Old 01-16-2005, 11:31 PM
Re: Re: Hesitation, stalling Please Help!!!
The thing is it happens with an almost exact pattern every time I leave the house it does this about 10 min. into my ride and continues for about 3 or 4 miles. As if its somthing to do with warming up? This is why I can't see it being a bad ground or connection ( of course I could be wrong ). Also the check engine light is not on.
I thank you all for the replys. Please keep the ideas coming.
Old 01-18-2005, 12:37 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: Re: Hesitation, stalling Please Help!!!
Get the codes scanned!
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-18-2005, 09:52 AM
vtmecheng vtmecheng is offline
"OBD I will not have a code unless the SES light is on" -GM Head Tech.
As for what you should do, I am sorry to say it is anyone's guess.
Old 01-18-2005, 11:53 AM
BlazerLT's Avatar
AF -Advisor
Bullshit, it will store the codes unless the computer is reset.
Old 01-18-2005, 01:28 PM
That is correct, it will store codes untill reset or the truck is started a certain number of times. From what he said unless a trouble code is triped, causing a dash warning light to come on, nothing is stored in OBD I computer systems. Is this correct, I dont know, just what the GM master Tech told me.
Old 01-18-2005, 02:07 PM
BlazerLT's Avatar
AF -Advisor
Not much of a master tech.
It is common knowledge that it will record and store any code unless it is the real primitive OBDI from the mid late 80s.
Old 01-18-2005, 08:54 PM
jackass#1's Avatar
this is from the haynes manual: the computer command control(ccc) has a built-in dianostic feacture which indicates a ptoblem by using a check engine soonlight
on the instrument panel. when the light comes on during normal vehicle operation, a fault in one of the informationsensor circuits or the emc itself has been detected. more importantly, the source of the problem is stored in the ecm memory.
soooo, if light has never been on no code exept for 12 letting you know the system is working(self dianostic).
Old 01-18-2005, 08:55 PM
BlazerLT's Avatar
AF -Advisor
Yip, and if there was EVER a code, it would be stored.
Old 01-18-2005, 08:59 PM
jackass#1's Avatar
he said his light was not on
Old 01-18-2005, 09:00 PM
BlazerLT's Avatar
AF -Advisor
And that means there is no codes stored?
Old 01-18-2005, 09:07 PM
jackass#1's Avatar
he said he changed the coil so i assummed he discconnnected his BATTERY when he did. which would have erased any prior codes.
