Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 01-16-2005, 01:28 PM
SuperPunch SuperPunch is offline
Angry 95 4.6l/P0402/P1407/Transmission slipping/Shudder/EGR
I don't even know where to start.
I've searched everywhere i just want my car to work correctly again.
In the summer my CEL came on periodically then went away. Finially it came on for about a week and I took it to Schucks and read the OBD II it came up with a "P0402 - Exhaust Gas Recirculation Flow Exessive Detected" At the time the guy at the time the guy at shucks told me it had something to do with emmision and not to worry about it.
About a month later my car started slipping out of gear... ehhh. So i took it to a mechanic. He reads my OBDII this time I get a P1407 (EGR something). And says that he doesn't know how that would effect my trasnmission. I take the car home and smell my transmission fluid it's burnt. Well my car was due for an oil change anyway so i have my oil changed and flush my transmission at jiffy lube. The car is running like a dream... for about a week. The transmission fluid smells burnt again...
So here I am with these cryptic OBDII codes. I think that somehow my transmission is getting way to hot.
And I have no idea where to begin fixing this stuff. Could someone with a little more car knowlege please shine some light on my situation?
Old 02-01-2005, 03:19 PM
njdjh2o njdjh2o is offline
Re: 95 4.6l/P0402/P1407/Transmission slipping/Shudder/EGR
I would say fix what the codes are saying what is wrong. and start from there.
The code are for a reason, so it you are getting them. That means does components are not working the way it should.
Just my little tid bit.
Old 02-01-2005, 06:45 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Does the temp gauge in your car ever climb more then normal?
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
Old 02-01-2005, 09:46 PM
Re: Re: 95 4.6l/P0402/P1407/Transmission slipping/Shudder/EGR
Not that I've noticed.
Old 02-01-2005, 09:57 PM
jspence35 jspence35 is offline
the egr symptom codes have nothing to do with the trans. they are probably caused by a bad dpfe sensor
Old 02-01-2005, 11:01 PM
I actually had my transmission looked at by a local trans shop and they tighnened something and did a premium transmission service and it's been running fine ever sense.
But the check engine light still wont quit.
Old 02-01-2005, 11:04 PM
a dpfe sensor does not usually cause any other concerns except the check engine lite
Old 02-01-2005, 11:07 PM
