Old 01-16-2005, 11:44 AM
River187 River187 is offline
Diagnostic
I have an 89' Ford 250. It recently started backfiring into the intake manifold. After a 600 mile round trip, it lost all power to the engine. I ran a code reader and came back with 11 O & 41 C. 11-0= something wrong with cylinder #1, 41-c=no hego2s detected. I replaced the o2 sensor but it still reads back that it still has a problem. I have no idea even where to start with the 1st cylinder.......any suggestions?
Old 01-16-2005, 06:56 PM
w8crz's Avatar
w8crz w8crz is offline
Send a message via MSN to w8crz Send a message via Yahoo to w8crz
Re: Diagnostic
I would check to make sure #1 is firing consistantly. It may be that #1 is misfiring every now and then.
Good Luck
Old 01-17-2005, 08:04 AM
DDeBoer's Avatar
DDeBoer DDeBoer is offline
Re: Diagnostic
Check your Distributor and your Coil for proper electrical output.
1985 F250 HD 4X4 7.5L DUALLY
SUPERCAB W/GOOSE NECK FLATBED
EDELBROCK PERFORMER #1406 CARB
EDELBROCK PERFORMER 460 INTAKE
FLOWMASTER DUAL EXHAUST W/4 INCH STACKS
Old 01-17-2005, 05:54 PM
mustangmike351c mustangmike351c is offline
if you dont have a bad plug wire or plug you might have a sticking intake valve. if all else fails pull the valve cover and check it out
Old 01-18-2005, 08:55 PM
Re: Diagnostic
Thanxs for all of the advice. I did fix my O2 sensor problem. Ended up with some loose wires. As far as the #1 cylinder, I haven't found out what is wrong yet. Either burnt valves, stuck valves or a bad cam. I dropped it off at a mechanics yesterday, so hopefully I will hear something soon. I did replace the distributer cap, checked all of the spark plugs and wires. The only thing I didn't do was a compression check, because of it taking two people to do usually.
Old 01-26-2005, 08:34 PM
FordTech4U FordTech4U is offline
Re: Re: Diagnostic
you 89 f250 is equipped with eec 4 and doesnt have the ability to pick out which cylinder is missing(no misfire monitor), i would probably guess that the code 41 dealt with bank 1 instead of cylinder 1, on an 8 cyl. engine, cyls. 1,2,3,4 would be on bank 1
