Old 01-16-2005, 10:58 AM
bangbg's Avatar
bangbg bangbg is offline
Question Supercharger belt?
I have a 2000 GTP 2-dr cpe with 115,000 on it that I use to commute 200 miles a day. Last week the blower belt shredded. I was able to drive the car home the remaining 85 miles after removing the shredded belt pieces. The car averaged 28 mpg with no blower belt for the 85 miles!
The idler pully looks like it failed and caused the belt problem. It is the single pulley positioned more towards the center of the engine not the outside one with inside guide attached. It definitely looks distressed and does not turn freely, it doesn't even look like much of a pulley.
Is that pulley R&R'd simply by removing the torque star fastener and replaced with one from an autoparts store? They are appearently available for about $20. I was afraid whatever bearing/bushing it was that failed is incorporated into a larger housing.
I don't know how to ask this question correctly. I have the new belt, and I need to replace the pulley. Is it easy or not?
Old 01-16-2005, 11:07 AM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: Supercharger belt?
Very Easy. I think it is reverse threaded 15mm if I recall
Old 01-16-2005, 11:22 AM
robTypeR robTypeR is offline
Banned
yes prob is its a chevy they do shit backwards all the time over there take it off put a new one on and install the belt shouldnt take more than 15 min
Old 01-16-2005, 02:31 PM
gregfor1 gregfor1 is offline
very easy job, i just did it, it takes about 10mins, one bolt to take out then just switch the pulleys
Old 01-16-2005, 03:30 PM
bangbg's Avatar
Muchas Gracias
I'm Supercharged again! Thank you for the advice. The idler pulley was the easy part, fighting with the belt re install was the longest part.
It looks to be fine now. Thanks again. It was a 50 Torx needed to loosen the bolt and it was threaded in the typical righty tighty lefty loosey fashion.
BTW I was really suprised how well the car ran without the SC belt on. Of course much less power, but it ran smooth and was very tractable in normal driving.
