engine removal
i have a 62 Buick lesabre with 401 i removed the bolts from the bell housing to the engine and metal cover on bottom of flywheel and engine mounts and can't seem to get engine free? do i have to remove some bolts around flywheel also? thanks mike
Re: engine removal
Is this an automatic tranny? It's been a few years since I removed an engine/transmission assembly fron a car, but I seem to remember the torque converter was attached to the flywheel, and you had to get a wrench in there and take out the bolts.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
Re: engine removal
You need to take the bolts off that connect the ring gear to the torque converter if it is an automatic. If it is a standard you will need to either slide the transmision back or the engine forward to get the input spine out of the clutch assembly. In either case you need to support the transmision or it will fall forwar as there is only a rear mount. Another thing that may be holding the engine to the tranny is the the two alignment dowels that go from the back of the engine into the bell housing.
