Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 01-16-2005, 07:16 AM
PLC PLC is offline
line blows off ,runs poorly
I have a 01 range 3.0L with 57k miles, today a line blew off the tube from the egr exhaust line reinstalled it started truck everything seemed ok drove off and it blew off again. It looks like it comes off the exhaust side of the egr, there is pressure coming out of the steel line. There are two lines next to each other the other one stays on, they go up into a box on the front of intake. truck is running like it is losing timing. though it could be pluged exhaust??
Thanks for any heads up info
Old 01-16-2005, 11:07 AM
rodeo02 rodeo02 is offline
Could be a blown diaphragm in the EGR valve, or maybe a plugged DPFE/transducer? (the box that feeds control vacuum to the EGR dome). Is your CEL on? The OBDII code will should help troubleshoot this.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 01-18-2005, 09:24 PM
PLC PLC is offline
Think i may have found problem. believe it to be pluged conveter.
Old 01-19-2005, 06:53 PM
Re: line blows off ,runs poorly
Hmmm... I'd be suspicious of that. Your 2001 will light up the CEL & give you a code from the downstream O2 sensor if you have a cat issue.
G/luck
Joel
