95 neon wont start
hey hows everyone doing...got a problem 95 neon wont start
I try to start and it cranks, but as soon as the RPM come up to 1000 it dies. I can get it to start if I give it a little gas. Once it warms up it will idle,but if I rev it it dies. The only fault codes I get are torque converter solinoid and O2 senor. I.m thinking its TPS or timing. Any help would be great!!! |
Re: 95 neon wont start
it probly is your 02 sensor the ecu uses that to tell if the right amount of gas is being injected into your cylinders I would replace that thern see what happens
Re: Re: 95 neon wont start
well i changed both up and downstream sensors and it started and ran better than it has been...new problem..wont start again. I drove the car around for an hr or so then parked it, had to go some where and the car would not start. all the lights work. when i turn the key nothing happens! it doesnt even attempt to turn the starter..i tryed to jump it thinking maybe the battery was low..no good...what next
Sounds like a electrical problem.. My battery has died atleast 10 times on me, now its to the point where i charge it, and try to crank it 12 hours after not being on, it starts off slow, then cranks. But if i crank it, turn it off, wait a hour, crank it again, it starts up fast.. its just if i wait a while to try to crank it again, i need O2 sensors too...
lucky, i wish i had money to do that too, im running so rich.. *12mpg* =/ |
